Excluding hollow pin chains, is there really a difference between the cheap chains, like a SRAM 951 and an expensive chain like a SRAM 991?
Weights are very close, within a few grams, and they all seem to have the same pin strength rating, 200 kgf. Is it really worth paying for the expensive chains? Discuss.
#2 (permalink) | |
BrewMaster (05-27-2008)
i think in the sram line, it is how the pins are pressed? i think they have ones that are just pressd, and some are double pressed? like look at the heads of the pin, there will be 2 lines or 4 lines...
other then that, i think the links in the better one are supposed to be more flexible, i am thinking the shape of outter links or something like a bump to help with getting up the gear shifting ramps? |
#4 (permalink) | |
Hors Catégorie
BrewMaster (05-27-2008),
Upchuck (05-27-2008)
Why not buy the cheap ones?
I agree, but pin strength is the only data they seem to publish as far as strength goes.
#7 (permalink) | ||
How cheap ![]() No reason not to I guess. I run the $20 PC-951 with no problems ![]() Quote:
![]() However I just change out my $20 Sram chain more often. Works for me. ps. BRING BACK 8 SPEED!!!!!!!!!!! ![]() ![]() ![]() |
tbowren (05-29-2008)
Yeah, I was referring to the PC-951. $15 can't be beat. The Wipperman ones look nice, but they are too pricey for me. I've never broken my cheapo chains.
DeeZee (05-27-2008)
Why mess with success ![]() Change out the cheap'o two or three times a year. I ran the wipperman back when m-bike chains were made for m-bikes (see 8- speed rant ). Would last a long time![]() |
trail-male for hire...
Buy one of these, and your cheap chain might just outlast your expensive chain.
wgb (05-27-2008)
I hate climbs!
Brew, if your process ain't broke then don't try and fix it. Unless you can find an added benefit to running a more expensive chain than the one that you currently use, then leave it alone.
For me, I am experiementing with chains. I don't want to get in the habit of spending more than I have to. I have never broken a chain, and I am not to the point of worrying about component weights. |
Marlboro Man in training
Edit: After rereading my post, it occured to me that it sounded a little boastful. Not my intention. Just saying a cheap chain doesn't have to take a lot of abuse to break. |
#15 (permalink) | |
Cassette and chain rings I will still clean with a toothbrush.
Rockinthecasbah (05-27-2008),
wgb (05-27-2008)
#17 (permalink) | |
Switched to this stuff about a year ago. Helps keep the drivetrain clean. http://www.rocklube.com/products_detail_gold.html |
mtnbikerfred (05-27-2008),
wgb (05-27-2008)
#18 (permalink) |
Shrek must be destroyed
i broke a 971, and a 991.
i run tghe cheap 951 until it dies.... (rare!). keep it clean, keep it lubed (kinda like other parts of life)
wgb (05-27-2008)
Get some mineral spirits and pour it into a big mouth plastic jar. Put the chain in there, let soak a couple of minutes then swish it around a bit. Take it out and wash with soap and water. Let dry and lube. I find that this is the most effective, thorough and easiest way to clean your chain. You can reuse the mineral spirits over and over again.
#20 (permalink) | |
Doesnt mineral spirits eat thru plastic?
