Old 05-25-2008, 06:40 AM   #1 (permalink)
_
LncNuvue's Avatar
Default Fork Options for Enduro SL
I have an 07 Enduro SL upgraded to 08 suspension. I've up'd the dampening pressure to max (65lbs) in the fork, this helped some. But I still have this problem - if I run it near or within the recommended sag it rides too low in the suspension and feels sloppy with little dampening, and jumps like poop (I enjoy leaving the ground, and the front wheel dropping out is not cool). When I run it firmer/less sag it feels better but the bump compliance lacks. Dialing this fork has been a serious work in progress. With that said, I'm ready to go a different route. Does anybody have recommendations for an alternative fork? I'm considering the 55ATA or ETA, Fox 36 Talas or maybe the Lyrik. Any input from someone that has dealt with this issue would be much appreciated. Thanks!
LncNuvue is online now
Old 05-25-2008, 07:59 AM   #2 (permalink)
it would help to know what fork you are running
Old 05-25-2008, 08:10 AM   #3 (permalink)
he's most likely talking about the specialized brand fork that came on the bike. i'd recommend the fox 36. i have it and it is ok. not spectacular but plush. my problem with it is lack of mid range support.
92se-r is offline
LncNuvue (05-25-2008)
Old 05-25-2008, 08:13 AM   #4 (permalink)
_
LncNuvue's Avatar
Sorry - stock Spesh 150e
Old 05-25-2008, 08:28 AM   #5 (permalink)
I have no experience with the speshy fork, so I can't offer any advice or recco on it, but, I recently purchased an 08 36 talas rc2. Coming from a 32 talas rlc, this fork was just the next progression in dialability, plushness, firmness. I mean, it was real easy to get dialed, I didn't have a problem when trying to dial out brake dive and having it effect small bump sensitivity. I find this fork very user friendly, it only took a couple a bit of trail riding to adjust everything and have it set up to my liking...
Sorry about the speshy fork, good luck with your search.
Red Hot Sloth is offline
Dirty Boo (06-11-2008), DownHillPhil (06-11-2008), FatWhat? (06-11-2008), LncNuvue (05-25-2008), Seat Sniffer (06-11-2008)
Old 05-25-2008, 11:19 AM   #6 (permalink)
Hurtin'
Magura Wotan would be my first choice. 160-120 remote adjustable and plush right out of the box.
Fox Talas 36 would be my second choice
I have heard good things about the RS Lyric
The recent stuff from Zoke leaves a lot to be desired.
I think it would be a good idea to go with a travel adjustable fork since you are losing the "brain" in the Spesh e150. That way you would still be able to climb by winding the fork down.
Old 05-25-2008, 11:39 AM   #7 (permalink)
Professional Lion Tamer
Keith B's Avatar
Speak to Carla at the Path (or her bloke) - she had a Fox 36 on the front and a DHX Coil on the back of hers.
I recently had my 07 E150 upgraded to 08 spec and the results are as you say - have you tried altering the pressure in the spike valve in the other leg? That will help with your problem. Either way 08 spec is alot better than 07, the less said about that the better.
"I once met three guys named pain, suffering and sacrifice. Now, we're inseperable. We're best friends"
Keith B is offline
cbHarping (05-25-2008), LncNuvue (05-25-2008)
Old 05-25-2008, 12:20 PM   #8 (permalink)
Got the Whistler blues...
cbHarping's Avatar
Close...I had a Rock Shox Lyric coil fork and a Push'd DHX coil on the back. It was nice to be able to adjust the fork down for climbs and let it out for descents, that's for sure.
I never did experience the Spesh fork, since I bought the Enduro frame alone and transferred my existing parts over from a previous bike.
cbHarping is offline
Old 05-26-2008, 05:55 PM   #9 (permalink)
cookie monsta
SnookDawg's Avatar
I recall reading a long-term test article in MB-UK or one of the other UK mags where they had the same problem getting that fork dialed - it was their main issue with that bike, so I guess you are in good company there.
The Lyrik would be sweet.
SnookDawg is offline
Old 05-27-2008, 02:07 PM   #10 (permalink)
Hecho en Japon
freekengo's Avatar
Are you sure you're setting the sag correctly? Your statement make it seem like you're setting the sag then sitting on the bike. One thing on my enduro is that if I'm just cruising around on the bike, the suspension feels like junk. Once you get that bike up to speed and the thing just comes alive! I run the front with the compression wound all of the way out and the rear is set loose. It still feels like it has too much "platform", but once you rock that bike, it "works"!
This is just my take on a 08' S-Works Enduro SL.
freekengo is offline
Old 05-27-2008, 03:28 PM   #11 (permalink)
ODB
Team Sting-Ray
ODB's Avatar
Loving the Lyrik Solo Air on my Pitch, which is nearly the same frame as the Enduro. If you want adjustable travel (not that important to me), however, you might want to consider the coil version with U-Turn.
Hanzo: "My fingers were raw from twisting the nipples."
BandMan: "I forgot my pocket pu$$y."
ODB is online now
Reba questions traumadiver The Workshop 8 02-25-2008 02:04 PM
Fork Help! freewheeler The Workshop 5 01-11-2008 10:23 AM
Front DH Fork Options sdyeti General Discussion 25 10-20-2007 07:48 AM
Which fork? Flat Broke General Discussion 12 10-08-2006 06:47 PM
fork options for a cannondale FyrFytrRyn The Workshop 6 02-19-2006 07:30 PM
