Old 05-24-2008, 11:00 AM   #1 (permalink)
Good Grasshopper
JOx2's Avatar
Default cutting steere tube, start nut question
once the steerer tube is shortened, do i need to move the start nut further down the steer tube? say if i cut 3/4" on the steer tube, do i need to move the start nut 3/4" lower?
JOx2 is offline
Old 05-24-2008, 11:09 AM   #2 (permalink)
only if its getting to close to the top of the fork like say within 1/4 inch or so
JOx2 (05-24-2008)
Old 05-24-2008, 11:12 AM   #3 (permalink)
Doing the 29er thing
Hey JOJO I just did some work on my bar height yesterday I went down about 1/2 an inch and yes you will need to move the star nut down too
XCMike is offline
JOx2 (05-24-2008)
Old 05-24-2008, 12:51 PM   #4 (permalink)
Dirtbag
DirtymikeTDB's Avatar
Yes, you will. You can tapp it down gently with the bolt installed and try your best to keep it straight, or have the LBS use the proper tool to put it at the proper depth and perfectly straight!!!
http://www.parktool.com/products/det...=50&item=TNS-1
Not a tool that I would say you need at home, seeing how often you wont be installing star nuts.
Originally Posted by deja vu View Post
....Leaving your nuts loose is always a good practice too, but sometimes hard to do when wearing lycra!
http://bighugelabs.com/flickr/motivator.php
DirtymikeTDB is offline
JOx2 (05-24-2008)
Old 05-24-2008, 03:44 PM   #5 (permalink)
I just installed one with a short piece of copper tubing and a hammer. It went pretty straight once it was all in there. You might want to have it done if it's cheap enough.
My Blog
JOx2 (05-24-2008)
Old 05-24-2008, 05:27 PM   #6 (permalink)
Edog's Avatar
Use a socket with about an inch OD
Ya that's right!
Edog is offline
JOx2 (05-24-2008)
Old 05-24-2008, 06:26 PM   #7 (permalink)
On the edge of chaos
Abui's Avatar
Only if you can't tighten the top cap to preload the bearings. Once the stem is set up you don't need the star nut, etc. though you might feel safer with it. LOL
Abui is offline
JOx2 (05-24-2008)
Effective top tube measurement question Evil Chocula The Workshop 2 05-03-2008 09:03 AM
Canyon Acres Poll Bergsteiger General Discussion 35 03-06-2008 10:41 PM
You tube question bighit8 General Discussion 5 03-01-2008 04:24 PM
n00b tube question: capnsavem General Discussion 2 01-30-2008 02:02 PM
26" tube on your 29" wheel? station Trail Talk 9 01-20-2008 09:58 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
