OC here I come!
What are the advantages/disadvantages to a SS specific frame vs a converted Hardtail. I am looking to build a 29er SS with a 80mm fork. It is almost cheaper to convert a geared hardtail (ie stumpjumper 29er) than to buy a rigid 29er SS and put on a fork. Plus I would always have all the gears if I ever wanted to ride it geared.
Any info would be appreciated. I've never owned a ss or 29er but I think I'd like it.
Does upgradeitis ever go away? |
EBB or Horizontal or Sliding dropouts make them better singlespeed frames. Without an eccentric bottom bracket on vertical dropout frame, you cannot tension the chain without a singulator or the like.
An EBB allows you to move the BB farther or closer to the wheel chainging chain tension. Horizontal dropouts let you tighten the wheel after the chain is tight.. pull it back to tighten it up. sliders have a track in which they slide horizontally, allowing you to tension it like ahoriz dropout.
Chewy THE Yeti Call me Chewy or Aaron VOODOO Gonzo 29 Big Boys ride.....BIG wheels. |
DeeZee (05-23-2008)
Harden The F*** Up!!
It is cheaper to convert an existing HT--since you aren't dropping $$ on a new frame. However, I like the SS specific frame a lot more. When you have a standard HT with verticle drop-outs and no EBB, you have to run a chain tensioner.
I converted a standard HT and HATED the tensioner. I thought it added a lot of drag. I bought a HT frame that had horizontal drop-outs which means no tensioner and I LOVE it. Just one jerk's opinion.
Less typing...more riding. |
#4 (permalink) | |
Ghetto Swan Lake
Stretch yourself before you wreck youself. |
tkblazer (05-23-2008)
i ride bikes
PacMan (05-23-2008)
Or get real real lucky and find the magic gear (thanks Neil) which is a 32:18 on my 07 rockhopper size small. The chain started out real tight but has since stretched a bit and still has good tension and have had no problems so far with a good 15-20 rides on it.
This only makes sense if you already own a decent hardtail, which in my case I already did.
| 2007 Specialized Epic Carbon Marathon M Frame | vukyle | The Market Place | 22 | 06-06-2008 01:49 AM |
| 19" Gary Fisher 29er Hardtail Frame | donkey | The Market Place | 2 | 03-24-2008 09:08 PM |
| Kona Cowen HardTail BMX/DJ frame (and some parts) | slowSSer | The Market Place | 15 | 03-05-2008 07:43 PM |
| Jamis Ranger hardtail frame $50.00 | skate | The Market Place | 1 | 08-11-2007 01:18 PM |
