#21 (permalink) | |
el_d00der1n0 (05-21-2008)
#24 (permalink) | |
And on occasion I've just jammed the cassette teeth in a piece of soft pine 2 x 4. But doesn't always grip enough on a stubborn one. The strap wrench is about 1/3 a chain whip price. |
Abui (05-21-2008),
foofighter (05-21-2008)
#25 (permalink) |
cool, Im glad you did the split pipe headset removal thing, I was wondering if that was gonna work
el_d00der1n0 (05-22-2008)
#26 (permalink) | |
oh yeah, thanks for posting that. i can't take credit for the idea. it worked really well. i was concerned it wouldn't contact the inside properly, but it seated rather nicely.
My Blog |
.8down (05-22-2008)
#28 (permalink) | |
First Run at Wheelbuilding
My Blog |
ChipsandSalsa (05-22-2008)
#29 (permalink) | |
Harden The F*** Up!!
We also use a wedge shaped block to remove the cups and fork races and that works great too.
Less typing...more riding. |
#30 (permalink) |
You can make your own with an old section of chain and small/skinny Phillips screwdriver. Run the screwdriver through both ends and that's it. I have the proper tool at home but have used this method a few times. Works like a charm.
el_d00der1n0 (05-22-2008),
foofighter (05-22-2008)
#31 (permalink) |
Duan'er - 29'er remixed
cool thanks man
#32 (permalink) | |
#33 (permalink) | |
Dirtbag
Ok, then its Not an Aheadset, Its a sealed headset. which is good, but Aheadsets are the nonsealed type like you had!!! I like your ingenuity, your remover you made is pretty much exactly what the tool actually is, the washer trick is far better than using a hammer and a block of wood. But I would go after using PVC pipe for the race installer!!! |
#34 (permalink) | |
![]() The mallet and wood concerns me because you won't have much opportunity to make sure it goes in straight if it's tight in there. I couldn't find PVC that I thought would fit right. The ID on 1 1/4 was just a little big when I was at the hardware store. The galvanized hasn't hurt anything yet, the clearances are very close, and it has some weight, so all you have to do is drop it like once.
My Blog |
#35 (permalink) |
So while we are on the headset thing, yesterday in the shop, and old lady brought in a really old tricycle for kids, that had a bike seat in the back but also a small seat. The kids this was made for must be tiny, but anyways, she wanted us to fix it because the handlebars and wheel were moving alot. We took a look at it and found out that the plastic spacer that acted somewhat as a headset had snapped and did not exist anymore.. well we took it apart and figured out a way to fix it. Then we had an idea, we got a 1" headset, and looked at it, it looked a little too big but heck, we tried it.. A couple twists of the tool and that sucker popped in. We're talking upwards of a 40 year old trike with a Headset on it! it worked flawlessly and the bars are awesome now. We also found spacers to fix the front wheel from moving side to side as you pedal. We were all kind of skeptical of the whole headset thing, but it worked well and surprised us all.
Brandon FLOres
You measure yourself by the people who measure themselves by you. This is How we do it! ![]() |
el_d00der1n0 (05-23-2008),
un-kola (05-23-2008)
#37 (permalink) | |
Go Angels!
(good job fixing the trike.)- Lloyd
BFloFoxRider. (05-23-2008)
#38 (permalink) |
Yeah, but you get a little more opportunity to correct it right? I have some bushings, a piece of cut steer tube, and bought more washers so I could guide better this time, but the cups went in a little too easily. I just cranked them down a touch to make sure they were in all of the way.
My Blog |
#39 (permalink) | |
)and actually, alot of the older ladies seem to like us for wahtever reason. We had a ~33 year old mom that was looking for a cruiser bike to ride around the streets with her kids and i told her she should get a 3 spd since we offer lifetime service which includes free gear adjustments, so she'd get more for her money if she got one and brought it in every few weeks so we can adjust everything. She then said she had gone to 4 other shops and i was by far the most help. All i did was answer her questions though... Oh then i went on and said something like "Wow NO other shops in the area could answer your questions and help you out? I guesss a 15 year old knows best " she was also surprised when i told her we could order anything in the catalogs i gave her and it would take ~1 week to recieve and build it unless they could not ship for some reason. ![]() Im gettting better at this job |
