Old 05-19-2008, 11:31 AM   #1 (permalink)
Default half links on a SS. chain talk
SO i put together my new SS, and to my dismay.. i COULD NOT get it tensioned .
with the EBB pushed all the way toward the rear wheel, i was about 1/8" away from connecting the pin... SO... i had to add 2 links (one male, one female...). With that setup, AND the EBB all the way forward, i couldnt take up all the slack!?!?!
so what chain do you guys run? a full pintle/halflink chain? or do you run JUST ONE half link?
how do you get the half link to match the rest of the chain? (width etc... all chains are different).
any help is much appreciated.... i love the SS!
VOODOO Gonzo 29
Big Boys ride.....BIG wheels.
Chewyeti is online now
Old 05-19-2008, 11:36 AM   #2 (permalink)
autoduel's Avatar
They make half links for 1/8 BMX chains as well as 3/32 8spd chains.
One is all you need.
Jenson has both as well as a full half link chain(although it will be heavier than a regular chain)
Steve
Just along for the ride
Originally Posted by SheDevil
Autoduel...yours is huge!!!
autoduel is offline
Old 05-19-2008, 11:37 AM   #3 (permalink)
Restepct.
Zippo's Avatar
hmm that's weird. you should be able to find a spot in the EBB's rotation that takes up the slack. I have enough in mine that I can run the same chain length on a 32x20 as I can on a 32x18. No half links here, just a SRAM PC58 with a power link. Take your rear wheel out of the drop outs and connect your chain before you loop it over the cog, and then mount the rear wheel.
When the going gets weird, the weird turn pro.
Zippo is offline
DeeZee (05-19-2008)
Old 05-19-2008, 11:37 AM   #4 (permalink)
Duan'er - 29'er remixed
well if you're going to something smaller than 22t in the rear then you should be ok...i was looking to do a 1/2 link but ended up changing frame LOL
www.coverageispersonal.com
Click the Button
foofighter is online now
Old 05-19-2008, 11:38 AM   #5 (permalink)
On the edge of chaos
Abui's Avatar
I''ve never had to use a half-link. Go back to your shorter chain and assemble it completely. Take the rear wheel off, place the chain on chainring, put the rear wheel in the drops while the chain is on the cog.
Abui is offline
Old 05-19-2008, 11:39 AM   #6 (permalink)
on the zion it was next to impossibel to do it was off by mere mm's and i couldnt get it on...at least this was my experience w/ that gear combo
Click the Button
Chewyeti (05-19-2008)
Old 05-19-2008, 11:42 AM   #7 (permalink)
i tried that and it was WAAAY too tight. i know it would work with a 21 tooth.
a half link would have been perfect.
I dont care about weight... i think i might run the full pintle chain and be bullet proof
VOODOO Gonzo 29
Old 05-19-2008, 11:43 AM   #8 (permalink)
21 tooth cough cough you wont have a problem from what i saw last night
otherwise
http://www.danscomp.com/464088.php?cat=PARTS
BrewMaster (05-19-2008), Chewyeti (05-19-2008)
Old 05-19-2008, 11:46 AM   #9 (permalink)
Abui's Avatar
What's your gearing? It's a Zion 29er, right?
Abui is offline
Old 05-19-2008, 11:49 AM   #10 (permalink)
si senor... 32 -22
VOODOO Gonzo 29
Old 05-19-2008, 11:51 AM   #11 (permalink)
try 21t i think you are more than able to heck i would venture to guess you'd be good at 20t...have you ridden anywhere else other than fully to get a gauge on the gearing?
just a hint OMR runs 34/22 on his 29'er and he climbs all day long
Click the Button
Old 05-19-2008, 11:52 AM   #12 (permalink)
You need to change cogs. You didn't suffer enough yesterday.
KonaDupee (05-19-2008), Rockinthecasbah (05-19-2008)
Old 05-19-2008, 11:55 AM   #13 (permalink)
exactually
Old 05-19-2008, 11:55 AM   #14 (permalink)
The ONLY place at fully i struggled was the first jaunt up the extra credit in blair witch. that initial section... i kept spinning the KLAW! and i got to the point where i stalled for a section... Pulling UP and PUSHING down at the same time.
i think i could do a 21.
OMR is a beast. You cannot compare him to a mortal such as myself. Apples to Astronauts!
VOODOO Gonzo 29
foofighter (05-19-2008), KonaDupee (05-19-2008)
Old 05-19-2008, 12:00 PM   #15 (permalink)
just saying im waiting for my 34t chainring and will be trying this...but seriously go do some other trails w/ that gearing to see...
Click the Button
Old 05-19-2008, 12:00 PM   #16 (permalink)
Abui's Avatar
si senor... 32 -22
I measured the EBB my Zion (Mt. SAC prize). It allows about .4" of adjustment but .5" is needed to cover all gear combos.
The good news is that you can use the shorter chain if you dremel 1/16" off the drops (one-half of your 1/8").
Abui is offline
Chewyeti (05-19-2008), foofighter (05-19-2008)
Old 05-19-2008, 12:04 PM   #17 (permalink)
yeah... seen the modify the frame trick. doesnt really interest me. thats the last place i want to increase clearances is the rear wheel mounting point.
VOODOO Gonzo 29
Pho'dUp (05-19-2008)
Old 05-19-2008, 12:07 PM   #18 (permalink)
that's what i ended up doing.
Click the Button
Old 05-19-2008, 12:24 PM   #19 (permalink)
Ghetto Swan Lake
Hey Chew. From what I read there's certain combos that don't work on the Zion frame. It's the EBB. Not enough offset. I think TeamDicky on MTBR replaced his stock EBB with a Phil Wood. He said the PW EBB had more offset than the stock one and probably would allow you to run more gears.
A BMX chain and a half link may work too. But I'd try just going 32:21 gearing.
Stretch yourself before you wreck youself.
Pho'dUp is offline
Old 05-19-2008, 12:31 PM   #20 (permalink)
listen to carl aka legs of steel
Click the Button
