Old 05-17-2008, 11:31 PM   #1 (permalink)
Default 2x9 Setup
So i currently have a 1x9 on my 29er and its killing me in my backyard (scully ridge + coal canyon) So i decided I will clutter my bars up and add a front derailer, simple but heres my question. Has anyone ever ran a 2x9 setup with a 38 -22 or something similar I was looking at the white industry setup and may try a 38-22 on my race face cranks since they are brand new. It just seems like 22-32 has alot of overlap and is lacking on the top end
I Think I Got White Lighting In My Eye **chewyeti**
Utopia Optics
powered by: www.deltaco.com
Old 05-18-2008, 06:08 AM   #2 (permalink)
I also like playing around with different gearing. I have found it much easier with Middleburn 5 bolt cranks.
http://www.mtbtandems.com/Middleburn.html
jake (05-19-2008), J_Sims (05-18-2008), Rockinthecasbah (05-19-2008)
Old 05-18-2008, 06:13 AM   #3 (permalink)
I think you might have a difficult time moving the chain up to the big ring with such a disparity in size.
Trailster is offline
Old 05-18-2008, 08:14 AM   #4 (permalink)
Chewy told me that front derailleurs can only go up or down by 12 teeth, so the max would be 20-32 or 22-34.
Dean, that link may up costing me too much money.
Solo rides are good for the soul.
Old 05-18-2008, 08:17 AM   #5 (permalink)
autoduel's Avatar
I'm running a 29x42 on my squishy. No lacking on the top end there.
29 is the smallest you can go on the middle ring on a 94bcd 5 bolt
Steve
Just along for the ride
Originally Posted by SheDevil
Autoduel...yours is huge!!!
autoduel is offline
Old 05-18-2008, 10:05 AM   #6 (permalink)
An Illustrated Scumbag
J_Sims's Avatar
I love my middleburns....
That's right 1/2 Horse power baby
J_Sims is offline
Old 05-18-2008, 10:21 AM   #7 (permalink)
this could get expensive
Utopia Optics
Old 05-18-2008, 10:40 AM   #8 (permalink)
most front derailers can do a 12 tooth difference between rings MAX.
so 20 + 12 = 32, 22 + 12 = 34 etc
Big Boys ride.....BIG wheels.
Chewyeti is offline
Old 05-18-2008, 12:25 PM   #9 (permalink)
which front derailleur are you running? i guess a 13 tooth difference is close enough to 12 to be ok.
Old 05-18-2008, 12:41 PM   #10 (permalink)
SLO Rider
Bryguy17's Avatar
hrmm...that 12 teeth thing throws a wrench in the cogs for me...
I was planning on doing something similar on my trailbike. drop the big ring in favor of a bashguard, and run a 36 or 38T middle ring in it's place to help out on the top end. I guess I'd be stuck with a 34T if i keep my 22t granny ring
Oh well, can't have everything
Bryguy17 is offline
Old 05-18-2008, 12:56 PM   #11 (permalink)
Share the Love
on my 26" bikes i normally run a 36T middle and 22T granny ring.. no problems shifting at all.. the good thing is a raceface 36T middle ring is easy to find, fits 104 bcd cranks and you don't have to change your cranks/bb
BrewMaster (05-19-2008), Bryguy17 (05-18-2008), Rockinthecasbah (05-18-2008)
Old 05-18-2008, 01:09 PM   #12 (permalink)
Epic Builder
GP_pilot's Avatar
I'm currently running a 22-32 2x9 w/ bash ring on my RIP w/ older 56 BCD cranks and a 11-34T cassette. Rarely to I find myself needing much more than 32 on downhill. I've thought of going 22-34, but even on flat road I can't keep up a continued pace in 32-11 w/ my Rampages. I've also thought of going w/ a shorter 20T granny, but I start to spin out sometimes in 22-34 on technical climbs in loose conditions. I think if I had a 29T, I could almost go 1x9 on my RIP since I'm on the 32 most of the time. But I've never ridden scully ridge & coal canyon, so your situation may be different.
GP_pilot is offline
Old 05-18-2008, 01:34 PM   #13 (permalink)
right now Im a 32 up fornt in a 1x9 and I spin down alot of long decents and I wouldnt mind being able to get a few pedals in
Utopia Optics
Old 05-18-2008, 01:54 PM   #14 (permalink)
SLO Rider
Bryguy17's Avatar
nice to know that the 36T will work tkblazer. I think I will try that at some point. Do you happen to have someplace you can find said chainrings for a 4-bolt 104mmBCD? gotta fit my '08 XT cranks.
GP, i think that the way you go down a hill really determines what gearing you want. If you're just cruising with the aid of gravity and not pedaling much, you likely wont spin out a 32T ring. I know i was fine with it until i started cranking down hills to go faster, then i started using my big ring more. Only problem is the 44T is a bit too tall of a gearing, so I can't get the acceleration out of turns that I would like. Switching to a bigger middle ring will give me the higher top-end that I need, but still offer low gears without worry of cross-chaining.
Bryguy17 is offline
Rockinthecasbah (05-19-2008), tkblazer (05-18-2008)
Old 05-18-2008, 01:58 PM   #15 (permalink)
Epic Builder
GP_pilot's Avatar
Then go w/ a 36T like tkblazer said and if that doesn't work bump down to a 34T. As a bonus, most bash guards will still protect either size.
GP_pilot is offline
Old 05-18-2008, 03:30 PM   #16 (permalink)
autoduel's Avatar
XT bottom swing with a ramped ritchey outer ring. I have not noticed any hesitation during shifts.
Steve
autoduel is offline
BrewMaster (05-19-2008), Rockinthecasbah (05-19-2008)
Old 05-18-2008, 06:33 PM   #17 (permalink)
Share the Love
np, i picked mined up a while back at the path but any bike shop should be able to get you one. i am using the race face rings and like them since they last long and are not too pricey
http://www.jensonusa.com/store/produ...hainrings.aspx
Old 05-18-2008, 06:35 PM   #18 (permalink)
Segregated non-bubb.
mechmann's Avatar
i run 26 36 on my XC race bike. good gearing IMO.
it is a shimano XT crank BTW
mechmann is offline
Old 05-18-2008, 07:54 PM   #19 (permalink)
SLO Rider
Bryguy17's Avatar
awesome...I think I may just try that out when my tax return/stimulus checks roll in
Bryguy17 is offline
Old 05-18-2008, 07:55 PM   #20 (permalink)
SLO Rider
Bryguy17's Avatar
.....double post
Bryguy17 is offline
