#21 (permalink) |
Buy the 5 arm Race face cranks from Shu...then finding 20 tooth and different chain rings sizes are easy. Or just buy ti, nothing wrong with that.
#23 (permalink) | |
I doubt I will use the granny ring to big cog that much, but I want more gear choices all around.
Rockinthecasbah (05-19-2008),
tkblazer (05-19-2008)
#24 (permalink) |
you want USABLE gearing.
you just said you wont ever use 20-34 in the back... so why even have it? why not liek 24 granny? you lose just a tad of your grunt gear. and you could run a 36 middle
Chewy THE Yeti Call me Chewy or Aaron VOODOO Gonzo 29 Big Boys ride.....BIG wheels. |
#25 (permalink) | |
![]() I am sure there are some really shitty climbs out there that would get me to use 20-34 gearing. It would be nice to have at those points.
#26 (permalink) | |
ok.. well here is my thought process. You have cleaned everything we have ridden with 22 granny and 34 cog. So keep that then, and go to a 34 middle ring? or maybe a 36 if you could get a derailer to hop that.
BrewMaster (05-19-2008)
#29 (permalink) |
I was thinking 26-36 or 38, does the spot lite bash clear 36 I really would like to not buy a new one
#30 (permalink) |
Team Sting-Ray
Running 24-36 on my Pitch with a Truvativ Stylo AM crankset and love it. Have never wanted for a higher or lower gear. I plan to switch my other bike to the same setup someday.
Hanzo: "My fingers were raw from twisting the nipples." BandMan: "I forgot my pocket pu$$y." |
#31 (permalink) |
I run and like 20 tooth grannies. It is not getting up a steep hill it is keeping the pedals moving after 30+ miles and 8 hours in the saddle. You don't have to use it but it is there if you need it. I sometimes use a 30 tooth middle ring...keeps the chain in the middle of the cassette 80% of a ride keeping a good chainline. I have a 20-30-40 spare Middleburn crankset set I use on some rides, most of the time it is 20-32-bash. All my bikes including my SS are square taper with self extractors so it is easy and fast to change gearing.
#33 (permalink) |
Malcontent
I run 22/36 on the X-5 and couldn't be happier with it. Great combo for me, and the 14 tooth jump has not been an issue whatsoever.
Currently running XT cranks & rings, but previously ran the same combo on an Atlas/ Blackspire setup and had zero problems there as well. Derailleur is an XT top pull, bottom swing.
jfsh: You do the wall ride for fun, not for pictures. The photos are just an added bonus. RacinJason: But what can they do take urine tests D&A samples? Last edited by Ladd Jasper; 05-19-2008 at 07:18 PM. Reason: Had the derailleur action backwards. |
#36 (permalink) |
SLO Rider
interestingly, I have never found much need for a gearing lower that 22-32. But then again, I tend to be a bit of a masher, and I run 180mm cranks which gives me a bit more torque. I do understand the idea of having a lower gear for the possibility of needing it, But I figure I may as well just get that little bit stronger and deal with a slightly taller gear. I'll end up getting up the climb faster anyway, which is always a bonus
#37 (permalink) | |
Locally: Go climb Clarks Grade in Big Bear then tell me you wish you didn't have a smaller granny gear. Remember we are talking 29ers here, gearing is different. Dean
If I'm not lost or getting bushwacked, the trail was too easy. Prescott Valley Houses The Path Last edited by dstepper; 05-19-2008 at 10:27 PM. |
Bryguy17 (05-20-2008)
#38 (permalink) | |
I want to run one with a 34 or 36 as well. |
#39 (permalink) |
I'm a FUN-GI!
Am I the only dude that uses big/little (42-11) on a regular basis?!
-Sean - Founding Member of the DNF-6 Race Team! 2007 KHS XC204 :: ...and a pair of Chevro-legs! "Justin had a warm spicy sausage...which I slowly munched on while I sipped Perpetuem and Pepsi." - Allison |
#40 (permalink) |
Dirtbag
I had a 22/38 combo for a very long time, At one time I had an LX front derailer, then I had an XT, then I had an X7, then it was Xgen.... guess what, they all shifted just fine, Basically I needed My ride to be able to climb, just like what your looking for Rock... I had for the small ring, a simple RF 22 ring, and since its tough to find a ramped 38 tooth, I took a 38 tooth 5 mm aluminum Azonic DH ring, and Put it on the lathe, shaved just a touch on the inside so it would fit and Blamo.... working system.
Now ther are 38tooth ramped rings out there, they are a bit costly, but if you have a ramped andf pinned ring, it will work much better. Now I am currently running a 22/36 combo, I lost a couple teeth on my ring, and I havent taken the time to get/find/mod another 38 middle ring. Still even jumping 14 teeth, it shifts excellent now, but thats probably due to having a ramped and pinned ring now. My suggestion, If your going to run a 2ring/bash system, stick with E13 DRS for a guide, simple setup, and they work friggin awesome. If your going to be at the next Fontana race, your welcome to check my system out. |
BrewMaster (05-21-2008),
Rockinthecasbah (05-20-2008)
