The topic of this installment is fork rebuilding and wiper seal replacement. I'm not a pro, but I want to encourage others to take the step like me and give the DIY a shot. You'll be much better prepared to deal with problems on the trail if you do...
So I posted a problem with my Tora leaking: IMG00172.jpg I went for a night ride last Tuesday and it got so bad it was squeaky. So, I decided to give the rebuild a shot. I've built wheels before, and so far, that was the most frightening and complicated thing I had done, so I figured this couldn't be too bad. So I went online, and SRAM publishes the Tora service guide. I'm sure all major brands do. It''s not too much trouble, but the Tora is just barely worth the effort IMO. By that I mean if you're thinking about rebuilding a Dart or RST or something, I wouldn't bother. The instructions are fairly straight forward. It's a good idea to read through them a couple of times first. I ordered the stuff I needed (fork oil, new seals) a couple of days ago from North of the Border Bikes, and Michael was very helpful. After picking up some tools at Ace (rubber mallot, 24mm socket, dowel), I was ready to go. Here's the workstation: IMG00173.jpg I would recommend a bike stand. I had a couple of moments when something to hold the upper part of the fork would have been nice. My oil pan. IMG00174.jpg Lowers are off. IMG00175.jpg They come off pretty easily if you give the bolts on the bottom a good whack. I tried a couple of times before I figured that out. You don't want to go whacking on the lowers directly though. U-Turn coil spring. IMG00176.jpg Lowers with the old seals. IMG00178.jpg Ok, so this was the most challenging spot. I tried pulling the seals out with plyers and they just got all chewed up. IMG00179.jpg And more chewed up. IMG00180.jpg I found a tutorial online and found a pic of someone prying them out with a screwdriver. You need to be very careful where the screwdriver makes contact with the sides or you will chip the paint like I did. ![]() And here's the finished product. New gray seals in place and fork back on. IMG00181.jpg I haven't ridden it yet, but it feels a bit stiff. I looked at the manual to see if I missed something or used the wrong amount of oil for the bath in the lowers. There's a chart at the bottom of the service guide that says I did use the wrong amount, and the wrong viscosity. I did get the right amount in the dampener though, so it should be pretty easy to replace the bath in the lowers. Anyway, there it is. Hope you enjoyed it.
My Blog |
1TrackMind (05-19-2008),
2wheel_lee (05-17-2008),
airgabe (05-18-2008),
Alex (05-17-2008),
BoingBoing (05-23-2008),
BrewMaster (05-19-2008),
ChariotsOfTires (05-17-2008),
Chewyeti (05-18-2008),
DBD (05-18-2008),
Dino Brown (05-17-2008),
Evil Chocula (05-17-2008),
foofighter (05-17-2008),
ghixon (05-17-2008),
JOx2 (05-17-2008),
Kid A (05-17-2008),
lukewiens (05-17-2008),
MTB26 (05-17-2008),
northshore (05-19-2008),
Pain Freak (05-18-2008),
quaestionis (05-20-2008),
RacinJason (05-18-2008),
Red Hot Sloth (05-17-2008),
RS VR6 (05-17-2008),
Seat Sniffer (05-17-2008),
Shu (05-17-2008),
Solo (05-23-2008),
station (05-17-2008),
strobelite (05-17-2008),
tbowren (05-17-2008),
TrojanInsomniac (05-17-2008),
un-kola (05-18-2008)
totally, but he's broken too. my daughter slammed him down on the patio. tune in to next time for gnome repair.
My Blog |
Alex (05-17-2008),
Cool rebuild. When I rebuilt my first Fox I was scared sh!tless that I was going to goof it up and destroy a $500 fork.
I did get an oil seal pick from Sears and it makes it a breeze to pull seals out now. Thanks for the step-by-step! Greg
more spin, less brake
I dig the tutorial with pics.
Tom |
el_d00der1n0 (05-17-2008)
Good Grasshopper
So d00derific!! i wish i can bleed brakes.
Reformed Triathlete
ghixon you bought one of these??
![]() as ghixon said, i need to do this same process with my pricey fox fork as well....and as well, i am scared sh!tless. on a scale of 1 to 10, how difficult would you say this process is. i guess you can only screw things up so bad during the process. any suggestions on using the seal pick? thanks.
"when you get hurt and all of your sacrifice adds up to nothing, are you willing to put it all on the line again?" - conrad stoltz MY BLOG - EMTB Quest for 24 hours solo |
el_d00der1n0 (05-17-2008),
ghixon (05-19-2008)
SLO Rider
nice job...Its fun taking apart forks, even without any reason. I modified a crummy marzocchi once to have 20mm more travel and be slightly plusher. it was great
![]() Also, with the seal pulling, I believe fox recommends using an adjustable wrench to pry the seal out, but I don't know if this would work for all forks ![]() |
Use an open ended box wrench. Much easier and safer.
CalEpic (05-18-2008),
SAR_boats (05-17-2008)
I don't think you'd have much success with the dental picks on those seals. Mine were cemented in there and very hard to get off. The box wrench might work, but you need to make sure you soften the blow or else you'll be chipping paint like I did.
I did my other Tora today. I didn't need to replace anything, so it went a lot faster. I think I could do one in 30 min to an hour now. It's pretty simple really.
My Blog |
I fall a lot
right on, good work dude.
#12 (permalink) | |
NO way in hell those picks will work on fork seals. I always have to crank hard on a screwdriver to get those seals out.
el_d00der1n0 (05-18-2008)
Yeah, that's right. If you do use steel, be very careful to just snag the o-ring with it, don't poke thru it. I use a piece of plastic rod cut at an angle to push out o-rings. A small wooden dowel could work too.
And Dood, your workshop looks a lot like mine -- on the patio, ice chest and lawn chair nearby. Steel-toed shoes & safety glasses? Naww...flip-flops and a beer! (although the results tend to be better if I hold off on the beer until I'm nearly done). edit: talking about o-rings here, not pressed-in fork seals...I usually use an old dull screwdriver reserved for that. |
#16 (permalink) | |
SLO Rider
![]() BTW, i found the fox service thing i had seen (credit fox service site): To remove the seals and dust wipers:
BRpunkRock (05-19-2008),
el_d00der1n0 (05-19-2008),
lukewiens (05-18-2008),
Pato (05-19-2008),
Solo (05-23-2008)
#17 (permalink) | |
![]() It was Old Guardian I think... Note to self: trim toenails before posting pic of feet in flip-flops.
My Blog |
OldDogDan (05-23-2008)
You can get a general sense of the condition of the fork by examining the foam rings. Dry foam rings indicate a lack of fluids or, possibly, a leak. Dirty foam rings may indicate a faulty dust wiper. In either condition, the anodizing on the upper tubes should be examined. If the anodizing has worn off due to insufficient lubrication, replacement of the crown/steerer/upper tube assembly might be necessary.
