Old 05-16-2008, 09:03 AM   #1 (permalink)
Default Broken Derailluer to Temporary SingleSpeed?
As I wait and wait for my birthday to come around (11 days), I had an idea. If I take the broken link out of my chain, press it back together on any given cog, I could potentially have a singlespeed. Is there anything that could cause problems? It seems logical to me.
EDIT: I forgot about the problem of rear suspension. On my Weyless XP 5" frame, I would most likely need a chain tensioner. :'(
DeadlyStryker is online now
Old 05-16-2008, 09:22 AM   #2 (permalink)
northshore's Avatar
Did you break the front or rear? Convert to a 1x9?
Hawaiian Island Creations
Ride it: dw-link.com/reasons
northshore is offline
Old 05-16-2008, 09:26 AM   #3 (permalink)
How to remove a chain, the correct way.
Broke the rear. Broke seems like an understatement. One of the chain links is bent out of wack as well. It broke in two.
northshore (05-16-2008), ransom (05-16-2008)
Old 05-16-2008, 09:37 AM   #4 (permalink)
northshore's Avatar
You "could" run it as a single speed even with the cassette on but A.) your chain line will be jacked B.) even if you did pick a gear on the cassette that could give you the right chain line your gearing might be off.
If you really really want to do it then I would use the front middle chain ring and like the 3rd to 4th gear from the outside for proper gearing.
Old 05-16-2008, 02:12 PM   #5 (permalink)
On my chain (Most likely a Sh#tmano) Err...Anyways if I take out a link can i push the pin back in or will I need a master link?
Old 05-16-2008, 02:15 PM   #6 (permalink)
northshore's Avatar
If it's temporary I would just get a quick link. Don't try to use an old pin once it's pushed out. The tapers on the end won't bend back. If the chain is really bad then you are better off with a new chain.
Vq/cc sailcalifornia Racing and Training 279 03-10-2008 05:47 PM
Anyone broken a bone here? BFloFoxRider. Rider Down 65 02-13-2008 06:12 PM
RR: Things I have broken in 2008 Edog Trail Talk 13 01-02-2008 09:33 AM
Why I Singlespeed (long) Upchuck General Discussion 21 12-15-2006 10:13 AM
