Old 05-15-2008, 05:26 PM   #1 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
Default So...apparently I can't change a tire...
Ok, this is flippin' ridiculous.
I have a Sun wheelset, and IRC Mythos XC (Kevlar) 2.1" tires. The tires do say "To fit HB-575 rim" whatever that means.
The tire is pretty close to impossible to fit on the rim all the way; obviously it's been done before as I was riding on it, but I seriously don't know how.
I replaced a tube and the "tight" section of bead that won't seat on the rim is about 8" long. Niether my standard levers nor my Quickstik are doing any good. I am trying to muscle it on using the "indian burn" method and I'm getting blisters on my hands.
Any pointers?!
-Sean - Founding Member of the DNF-6 Race Team!
2007 KHS XC204 :: ...and a pair of Chevro-legs!
"Justin had a warm spicy sausage...which I slowly munched on while I sipped Perpetuem and Pepsi." - Allison
L8 APEKS is offline
kevinator (05-16-2008), station (05-16-2008), Zippy (05-15-2008)
Old 05-15-2008, 05:32 PM   #2 (permalink)
soap and water on the tire and the rim usually helps me put on even the toughest tires or new tires.
skate is offline
Pho'dUp (05-16-2008)
Old 05-15-2008, 05:32 PM   #3 (permalink)
http://www.jensonusa.com/store/produ...y.aspx?sc=FRGL
Old 05-15-2008, 05:32 PM   #4 (permalink)
northshore's Avatar
I have those exact same tires. I had to use two tire levers on my DT540s before. Just sorta inched it along.
Hawaiian Island Creations
Ride it: dw-link.com/reasons
northshore is offline
Old 05-15-2008, 05:39 PM   #5 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
Metal levers? Aren't those going to scratch the heck out of the rim?!
L8 APEKS is offline
Old 05-15-2008, 05:48 PM   #6 (permalink)
Geddyup!
CPATCRASH's Avatar
Hope you never get a flat on the trail!
Cowboy.
CPATCRASH is offline
art23rockpile (05-16-2008), station (05-16-2008)
Old 05-15-2008, 05:57 PM   #7 (permalink)
Karnivore
mtbchip's Avatar
Wow. I use those tires frequently w/out that problem. Mavic X517 rims. No air in the tube and pinch them toward the center (as I'm sure you know this) and pull a bit. I actually sit on my hin'ne, bare foot, holding the rim with my toes and pull the tire up and around the rim to get as much slack as possible. Weird. I had a set of Intense 2.25 that I could NOT get on my rims.....
Good luck.....
mtbchip is offline
Zippy (05-15-2008)
Old 05-15-2008, 05:58 PM   #8 (permalink)
HELLDOG's Avatar
Make sure all of the air (if any) is out of the tube. Also, try to get the portion of the tire that is on the rim towards the center. I usually pinch the tire together with both hands while wiggling back and forth. And then go back to the portion that is not set and give it one more try. (hope that makes since) A good set of tire levers will help as well. I like PEDROS levers. they are very strong. GOOD LUCK.
HELLDOG is offline
Old 05-15-2008, 06:00 PM   #9 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
Well, apparently, spit is good all sorts of places.
Lubricated the Quikstik and was able to pop it in. You can quote me on that.
Thank you guys!
L8 APEKS is offline
mtnbikerfred (05-16-2008), Zippy (05-15-2008)
Old 05-15-2008, 06:08 PM   #10 (permalink)
You're right it could scratch, don't care, it is not like I don't already have bunch of dents and scratches in my rims.
Old 05-16-2008, 07:12 AM   #11 (permalink)
I got something similar to what Dean mentioned. I got Soma tire irons at the Path. Its plastic on the outside and metal on the inside just in case youre worried scratching your rims. FWIW I snapped 2 of those Pedros tire irons trying to mount Maxxis Highrollers on Sun rims.
Hanzo is offline
art23rockpile (05-16-2008), kevinator (05-16-2008), Pho'dUp (05-16-2008), station (05-16-2008)
Old 05-16-2008, 07:17 AM   #12 (permalink)
found my special purpose
Kid A's Avatar
u will never get that 26 tire on a 29'r rim
RIP: Taco Tuesday Funky Bunch
Calling all Freaks -> http://www.socaltrailriders.org/foru...funkathon.html
Kid A is offline
Old 05-16-2008, 07:20 AM   #13 (permalink)
Pickettt's Avatar
HB stands for "Hook Bead", we know them as "clinchers". As for the 575, a typical mountain bike rim is about 575 mm in diameter. I know none of this helps you mount a tire, but there it is.
Pickettt is offline
L8 APEKS (05-16-2008)
Old 05-16-2008, 07:36 AM   #14 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
That's ok. The 29 fad will die before I have to replace these tires.
L8 APEKS is offline
Old 05-16-2008, 07:36 AM   #15 (permalink)
FatPossum's Avatar
+1 on the two levers
I never have- but have heard of others people using the soap and water technique.
Hope you get it on soon!
FatPossum is offline
Old 05-16-2008, 08:23 AM   #16 (permalink)
Senile Member
kevinator's Avatar
2 yellow Pedro's levers. And wear some glasses - I've almost been blinded by little plastic missiles from levers disintegrating.
Expensive Lightweight Shit
kevinator is offline
Old 05-16-2008, 08:33 AM   #17 (permalink)
Pedal Damn It
davidB's Avatar
don't feel bad, i have a popped blister on each thumb from when i took forever to get SM8's onto Stan's Arches. God help me if i ever have to do that again.
davidB is offline
Old 05-16-2008, 08:33 AM   #18 (permalink)
Is this thing on?
station's Avatar
run a bead of spit on the edge. If you're on the trail have your buddy yell cougar! You'll pop that tire right on.
station is offline
Old 05-16-2008, 08:38 AM   #19 (permalink)
Senile Member
kevinator's Avatar
how about "cougar shirt!"
Old 05-16-2008, 08:42 AM   #20 (permalink)
Or Not Enough
TooManyTacos's Avatar
Yeah, this seems to be an issue with some of the Sun brand rims. I've had similar problems with getting the last part of the bead on my Rhynolite XL and MTX rims. Same tires on Mavic rims are just fine. It's kind of annoying, but now that I know what to expect, I can mentally prepare myself.
TooManyTacos is offline
