I have been trying to figure this one out for a few weeks now. It higher speeds I will get a rubbing pinging noise from my brakes(at least i think its the brakes). I am not sure if its the front or the rear. I can duplicate it unless I am riding at high speed, a lot of the time its coasting down hills. Any ideas, or is it something I shouldn't worry about.
I'm a FUN-GI!
I get the very same thing. I was just checking all my brake hardware to make sure there was nothing loose.
If I lightly drag the brake, the sound goes away...but if I spin the tire, it does not rub at all. It's vibration from the rotor, and I think it's normal. Out of curiosity, what size rotors do you have? I have 203's, and I noticed only the front vibrates.
-Sean - Founding Member of the DNF-6 Race Team! 2007 KHS XC204 :: ...and a pair of Chevro-legs! "Justin had a warm spicy sausage...which I slowly munched on while I sipped Perpetuem and Pepsi." - Allison |
SLO Rider
My money is on it being the front wheel. As was mentioned, It's probably at least partially vibration induces. Also, if you have a QR front wheel, the lowers/axle/QR interface will flex just a smidge from time to time and cause a zing.
you can tighten the QR a bit to help, but it's not really necessary. also, moving to a smaller rotor may help, but thats not an option for most people Honestly, If its just zinging periodically (not a constant thing) i wouldn't worry too much. my front brake does it and i dont mind. at least it isn't screeching like mine when they rub ![]() |
I'm a FUN-GI!
Avid BB7, 203mm, QR front.
Totally normal noise. Nothing to worry about. Just check the rotor bolts now and then and all the brake mounting bolts. It's worse on some bikes than others. One more good reason to stick with v brakes....LOL
The jesus and Mary Chain is the greatest band ever
#15 (permalink) | |
Shrek must be destroyed
Your rotor is similar to that... it tries to stay in its axis of rotation ![]()
#16 (permalink) | |
Suspension Junkie
Yeah this is happening at higher speeds no braking. Its not all the time its comes and goes. Based on the responses it seems like it not something to be overly worried about when it happen here and there, if it gets worse then I will worry.
Brakes Juicy 3 with 8" Hayes front rotors. |
#18 (permalink) |
All my words are rubbish
i was getting a shrill, annoying vibration whine from my front 185mm Juicy7 and swapped the front and rear rotors and it went away, never to return. Just a suggestion if you are running the same size rotor front and rear. And i saw someone post about creating that grind in a turn, which will generally only happen on QR-axled wheels because the allow more lateral flex.
What's that smell? |
#20 (permalink) |
Red Hot Sloth (05-16-2008)
| Hayes Disc Brake 5" Rotor | BobBurnes | The Workshop | 6 | 02-25-2008 04:55 PM |
| brake pads rubbing | JOx2 | The Workshop | 6 | 01-24-2008 08:33 PM |
| Hayes Brake Rotors & Pads | project_d | The Workshop | 10 | 10-17-2007 09:40 PM |
| Check your brake cables | UR2KLOS | General Discussion | 15 | 09-07-2007 12:28 AM |
| Brake lever pin missing | Paul000 | The Workshop | 4 | 08-07-2007 12:09 PM |
