Old 05-13-2008, 01:21 PM   #1 (permalink)
Default Removing Chain
So I was trying to remove my chain to clean it the other day and did not notice a removable link. Is there a certain way I am supposed to take the chain off? Buy a better chain?? I am also worrried about breaking it at the Travers and not being able to re-assemle it.
Sebastian is offline
Old 05-13-2008, 01:27 PM   #2 (permalink)
77 65 79 6C 61 6E 64
dubjay's Avatar
I'm guessing it's a Shimano chain? If it is, you'll need a chain tool to press one of the pins out.
When you go to re-assemble it, you'll need a new Shimano pin (they are not re-usable) or you can just put in a SRAM Powerlink so removal is easier next time.
dubjay is offline
DeeZee (05-13-2008)
Old 05-13-2008, 01:29 PM   #3 (permalink)
Thats the wierd thing, I tried using that tool to push a pin out, and it just bent the tool. Was there a master pin I was supposed to see? Maybe just a cheap tool? I bought in a set with a box at REI.
Old 05-13-2008, 01:36 PM   #4 (permalink)
dubjay's Avatar
You should be able to press out any pin. There is no master pin. That's just odd - maybe it is just a cheap tool?
dubjay is offline
Sebastian (05-13-2008)
Old 05-13-2008, 01:37 PM   #5 (permalink)
I am thinking the same thing. I am going to buy a new tool.
Old 05-13-2008, 01:39 PM   #6 (permalink)
dubjay's Avatar
Just to be sure - you're trying to push one of the pins like this?
dubjay is offline
Old 05-13-2008, 01:43 PM   #7 (permalink)
Well, I might actually have put the chain on the first setting rather than laid it flat against the back like you shown. (I cant really remember) Maybe it WAS my bad. Either way, gotta buy a new tool!
Old 05-13-2008, 01:45 PM   #8 (permalink)
Rawhead's Avatar
I would suggest purchasing a chain cleaning kit. No need to take the chain off the bike just to clean it:
http://www.performancebike.com/shop/...slisearch=true
I'd rather be riding my mountain bike thinking about God than sitting in church thinking about my mountain bike.
Rawhead is offline
mtnbikerfred (05-13-2008), northshore (05-13-2008), Sebastian (05-13-2008), supralight (05-13-2008)
Old 05-13-2008, 02:10 PM   #9 (permalink)
Thanks for the suggestion. I will probably end up doing that too. I would lke to have a chain tool in my pack incase my chain bust too.
Old 05-13-2008, 02:51 PM   #10 (permalink)
Beer! How did you know?
LoisMustDie's Avatar
...good idea to have a new chain for big races.
"He was a wise man who invented beer." - Plato
RES FIRMA NITESCERE NESCIT
LoisMustDie is offline
Old 05-13-2008, 04:14 PM   #11 (permalink)
On the edge of chaos
Abui's Avatar
But break it in two weeks early.
(to be continued)
Abui is offline
Old 05-13-2008, 04:18 PM   #12 (permalink)
Well I was thinking more like bringing a couple links so you can repair the chain on the trail. I would imagine a chain to be somewhat heavy.
Old 05-13-2008, 04:29 PM   #13 (permalink)
Derailleurs R4 Failuers
hoovermd's Avatar
I highly recommend that you install a Wipperman link as this is a tool-less master link.
I use 'em on all my SS bikes and they are sweet.
I also carry a chain breaker in my pack along with an extra Wipperman and a sort length of matching chain
IMHO, chain cleaning is overrated. Factory lube is da Bomb, but BoeShield is good too.
Ride it, wipe it, lube it.
Let it sit a day and wipe it again.
Replace it when it looks like it has stretched.
Mark
hoovermd is offline
Old 05-13-2008, 04:31 PM   #14 (permalink)
andygua's Avatar
There are certain shimano chains that have only one pin that can be pressed out (well, not sure if it's only one, but am sure that not all of them can be and it's a big pain looking for "the" one). I had one of that chains and learned this the hard way...bent my tool, took it to the lbs, the guy couldn't do it with their big tool and then an experienced guy jumped in and illuminated us...
Just roll through the chain and look for one pin-head that's completely flat (the rest will have a little "hump"...dunno how to call it )...push that as much as necessary to remove the inner plate (never push it all the way, otherwise you'll have to get a new chain since it's the only pin that can be pushed )
Guess why that chain is no longer in my bike
Good luck!
andygua is offline
Sebastian (05-14-2008)
Old 05-14-2008, 07:44 AM   #15 (permalink)
ali'i hua
slowSSer's Avatar
master link- absolutely-
i agree with all that you've said here except that last sentence- get a chain stretch tool/gauge.
here's the worst part- if your chain and drivetrain have all stretched/worn together, a new chain is going to cause more issues-
example: stretched chain and cogs/chainrings with flatspots in the "valley" have all worn in together. a new chain (not stretched) with the older worn gears is going to be a nightmare.
slowSSer is offline
Bash Guard/Chain Length nappyt The Workshop 14 01-26-2008 06:11 AM
cassette and chain help!! lukewiens The Workshop 14 12-21-2007 07:42 AM
Bad Link in SRAM 971 Chain ghixon The Workshop 12 12-09-2007 02:34 PM
S/S chain question! guero The Workshop 41 02-08-2007 05:09 PM
