Old 05-11-2008, 06:23 PM   #1 (permalink)
FatPossum's Avatar
Default adjusting rear shock pressure
STR peeps,
how do I determine how much pressure to have in my rear shock? does it have to do with my weight & size? I'm 6'3 and 195lbs if that info is necessary.
thanks for your advice in advance!
FatPossum is offline
Old 05-11-2008, 06:30 PM   #2 (permalink)
I'm assuming this is an air shock.
Set pressure by measuring sag. Shoot for 25% sag. For example, if the shock has a 2" stroke you want ~ 1/2" of sag.
To measure:
If there is an o ring on the shaft of the shock push it all the way up against the shock body. If not use a zip tie.
Sit on the bike with your riding gear and Camelbak on. You want to measure using the weight you will be riding at. Don't bounce around. Make sure if there is any sort of pro pedal or platform on the shock it is all the way open.
Measure how far down the shaft the o ring or zip tie moved my sitting on the bike.
Adjust air pressure accordingly.
FatPossum (05-11-2008), mtnbikerfred (05-11-2008), springrubber (05-11-2008), station (05-11-2008)
Old 05-11-2008, 06:31 PM   #3 (permalink)
Originally Posted by FatPossum View Post
STR peeps,
If it's an air shock it's easy. Check manufacturers spec for the amount of sag the shock should have. (sag is the amount the shock compresses with you just resting on the bike balancing yourself with something. You can use an o-ring or sip tie on the shock shaft to measure) Sag is typically 1/4-1/3 of total shock compression. Mess with the air pressure until you get it right.
If it's a coil shock setting sag is a little more tricky, you have to basically eyeball it ( you can but a zip tie on the small inner shock shaft but it's a pain in the butt) Good luck.
Rivet is offline
Old 05-11-2008, 09:07 PM   #4 (permalink)
FatPossum's Avatar
it is an air shock - thanks for your replies. I will gear up with the camelbak and shoot for the 25% sag.
Cheers-
FP
Old 05-11-2008, 09:27 PM   #5 (permalink)
Which bike? Some bikes require more sag than others. Check your bike manual or manufacturer's web site for the correct sag for your bike.
bcblur is offline
FatPossum (05-12-2008)
Rear shock sizing Seat Sniffer The Workshop 18 05-02-2008 07:30 AM
WTB: rear shock Shu The Market Place 7 04-02-2008 08:36 PM
Anyone else have problems with Specialed rear shock? Scott V The Workshop 13 02-07-2008 05:48 PM
SOLD!!! YETI ASX lg w/ Rocco rear shock upgrade J_Sims The Market Place 19 01-03-2008 04:11 PM
Fox Rear Air Shock BUSHING? PHAT TIRE The Workshop 4 03-12-2007 04:57 AM
