Old 05-09-2008, 04:55 PM   #1 (permalink)
Small, but Mighty
Zippy's Avatar
Default Der Cage Length: What's it mean?
Long? Short? I know rear derailleurs come in various lengths, but why? Is one better than another? Are they designed for specific applications?
Definitive knowledge please, not: "It's not the size of the cage, but how you use it that counts..."
Thanks!
L8 APEKS: "Never underestimate the power of stupid people in large groups."
Swim, bike, run.
www.zippyathlete.blogspot.com
Zippy is offline
Old 05-09-2008, 05:02 PM   #2 (permalink)
Bloated Ogre
jeffj's Avatar
Depends how much slack it has to take up due to the various chain lengths needed for various gear combinations.
A road bike two-chainring setup may get away with a short cage derailleur with a cassette that doesn't have a wide range.
Derailleurs usually state how much of a difference in range they can handle expressed in 'teeth'.
A long cage RD can handle something like a 42 tooth difference between 1x1 and 3x9 on a MTB. Add up the teeth on both extremes of the shifting range and see what the difference is.
On a MTB, it may be an advantage to use the shortest cage that works so the derailleur doesn't hang down as far and present itself to rocks and other snags.
jeffj is offline
Dino Brown (05-09-2008)
Old 05-09-2008, 05:03 PM   #3 (permalink)
Secret Squirrel Society
davidB's Avatar
good thread about this and most everything you'll want to know is in the 2nd post
"The Path is simply the best bike shop in Southern California." - Brewmaster
www.thepathbikeshop.com
davidB is offline
Zippy (05-09-2008)
Old 05-09-2008, 05:04 PM   #4 (permalink)
Reformed Triathlete
lukewiens's Avatar
i believe the longer the cage the better quality and more consistent shift you will get. shorter cages are beneficial in clearance situations or when you are bashin' through a bunch of rocks!
that's what i've been led to believe anyway!
check this...
http://www.beyondbikes.com/bb/tech/?section=rdr
now i know!
"when you get hurt and all of your sacrifice adds up to nothing, are you willing to put it all on the line again?" - conrad stoltz
MY BLOG - EMTB Quest for 24 hours solo
lukewiens is offline
Old 05-09-2008, 05:19 PM   #5 (permalink)
Small, but Mighty
Zippy's Avatar
Excellent answer. Thank you.
Swim, bike, run.
Zippy is offline
Old 05-09-2008, 07:04 PM   #6 (permalink)
That is a great (technical) explanation. Practically speaking I have always understood that a short cage D would normally be used only on a 1x9 application, such as a DH bike, as there is less variation in chain length. On a 2x9 or 3x9 there is more variation, therefore you need the longer D to take up more slack. I guess thats the gist of what he says.
evdog is offline
cage length? chauvinist_youth The Workshop 7 04-11-2008 01:35 PM
Rear Der, long cage or medium cage? JOx2 The Workshop 8 03-15-2008 05:38 PM
Updated info on Cleveland Forest Closures genusmtbkr5 Trail Talk 34 03-13-2008 08:57 PM
King Ti Water Bottle Cage 1 month old $40 Padre The Market Place 1 02-08-2008 05:51 AM
lost about medium and long Cage Derailuers.. .8down The Workshop 14 10-29-2007 02:43 PM
