Hi Guys,
This weekend I started riding and noticed a strange noise...whenever I sat on the bike (yeah, I'm a big dude) and started rolling the wheels there was a sound as if the spokes where loose (a constant "ding" bell-like sound)... I stopped, and went through every spoke to check if they "sounded" different (when slightly hitting them), but they didn't seem to... Maybe all of the spokes are a little loose and when I sit on the bike they will slightly bend and produce that sound as the wheels roll? What do you experts think? I still made it to the top of Sullivan Canyon (I think that's Mullholland right?) and back...my first "long" ride in LA ![]() Btw, the wheels are a pair of Crossmax SL's...I couldn't tell if the sound came from the front or rear wheel though (maybe both ) |
You should have your wheels retentioned. The sound is your wheel flexing and the spokes rubbing against each other. It can cause excessive wear. A shop can normally tell if they came lose.
I am thinking it is your rear wheel. Because it is under much more twist load. |
Are you sure the "ding" noise is coming from the spokes? I would carefully listen for the noise and be sure you find where it is coming from. It might be something silly.
One time I noticed the front wheel on my road bike was making a strange "twang" noise (similar to rattle sound of a broken pool que stick). I couldn't figure out where it was coming from... turned out that the nut on the tube valve stem was loose and making the noise. Inspect that thing one more time!
I'd rather be riding my mountain bike thinking about God than sitting in church thinking about my mountain bike. |
I took my bike to a regular service at Helen's (I know, never again, very bad service) and I think they did true the wheels...but since the overall service didn't give me a good feeling, I thought they just might have left some the spokes loose...
Maybe it's that they are untwisting...although the sound was there when I got back to my car after doing Sullivan...should I give them a little more time to untwist? I'll re-check if the noise is coming from the wheels, but I'm quite sure it is (although it's hard to tell when you are sitting and pedaling!) Thanks for your help! |
Old man goin' downhill
"DING" - check the rotor.
If a rotor bolt or two is loose you will get an occasional "ding" from it contacting the caliper. edit: If the rotor is warped you can also get the same sound. Spokes really do not make a "ding" sound unless they are completely out of the nipple and hitting something and that would be easily spotted when you check all the nipples. If the spokes were not pre-stressed when the wheel was built you will get a sort of high pitched creek out of the spokes as they settle in. ![]()
I think that's a better description of the sound I have...the weird thing is this is a used bike, and I doubt the spokes are settling down anymore (I assume they already have, after a year or so of normal use).
Is is possible that the spokes need a higher tension for a heavier guy? Maybe they were ok for the previous owner's weight, but not for me, and need to get retentioned? Just a guess... This is confusing ![]() |
| Interesting analysis on spke patterns and stiffness! | Chewyeti | General Discussion | 0 | 05-06-2008 07:32 AM |
| Im such a SS'ing monster I broke a spoke... | foofighter | General Discussion | 18 | 03-23-2008 09:21 PM |
| Did someone loose fluffy? | foofighter | The Pub | 16 | 03-03-2008 06:02 PM |
| Check out this BIKE! I hope I don't Loose a Shoe | IM4Ruckus | General Discussion | 3 | 12-21-2007 10:20 AM |
| Loose levers on Magura Martas | Saosin | The Workshop | 2 | 06-15-2007 08:58 PM |
