.8down
parts hoarder
.8down's Avatar
check this out:
http://www.instructables.com/id/SUVBY0CF82EXOD9/
Originally Posted by .8down View Post
Hi my name is Thai and I'm a Partsaholic
Pato (05-08-2008)
Pato
Pato's Avatar
aIm gonna try to remove my headset, so you coat the screw driver with anything, tape? no scratches on the ano?
If you are referring to the headset cups, no need to wrap the screwdriver. You will be knocking the cups out from the inside so the scratches will only be cosmetic and your frame will not be anodized in there anyhow. Just take your time and alternate sides as you hammer the cups out. The goal is to knock it out evenly to avoid ovalizing the cups or the head tube.
evdog
I've done the ghetto method on a road trip when we did not have access to a shop. But with something hi-quality like a King headset, and presumably a nice frame, I would not be trying to save a few $$ by doing it myself unless its an emergency.
Pato
Pato's Avatar
No need to worry about the ghetto method. Using the press I built, it is nearly impossible to damage the headset. If you make sure the cups are going in fairly straight you'll splinter the wood before you damage the cups.
evdog (05-09-2008)
gr@sshopper
I've done the allthread DIY press a couple of times, but I think I buggered up the most recent one. It feels sort of sloppy, like the cups are moving in the headtube a little.
el_d00der1n0
Creature of the Wheel
you might have ovalized your head tube if they didn't go straight in. that's why i've been working on a better design that uses bushings to keep it straight.
all your macs are belong to us
.8down
parts hoarder
.8down's Avatar
how much is this DIY press costing to manufacture with materials and all? I think price point has one for 50 bucks..
el_d00der1n0
mine is about 3 bucks so far. i have a bunch of spacer bushings left over from hanging the lcd on the wall. i think they'll work...
.8down (05-13-2008)
OldDogDan
OldDogDan's Avatar
OK, my $.02. If you're good mechanically, and VERY CAREFUL to start it STRAIGHT, there is no reason you can't DIY. The threaded rod idea should work well. Here's another. I had a really big C clamp hanging around, and that worked great. Start it with careful light taps of hammer on block of wood -- be SURE it's straight, then press it in with blocks of wood and C-clamp. If you're having problems, yeah, stop and go to the LBS.
.8down (05-13-2008)
foofighter
Duan'er - 29'er remixed
that's hot...
-Duan
Dulce et Decorum
Click the Button
.8down (05-13-2008)
.8down
parts hoarder
.8down's Avatar
cool can I borrow it? hahaha. or better yet can you install a headset for me?
el_d00der1n0 (05-13-2008)
dubjay
我是鄭偉倫
dubjay's Avatar
Just use a dumbbell set!
I actually just went out and bought my own headset press and remover from Price Point. I've used it enough on my own bikes (and friends' bikes) that it's probably more than paid for itself already - especially when you start charging beers to press in headsets.
.8down (05-13-2008), autoduel (05-13-2008)
.8down
parts hoarder
.8down's Avatar
dood, Fing Brilliant,
gr@sshopper
It's possible, but I honestly used almost no force at the start. Maybe I'll pop em out, and check with the calipers.
I kind of also wonder if I didn't get them in enough.
Chewyeti
and to make life easier... i put the frame in the sun before i do it... and freeze the cups for an hour or two.
come back from class/ride/whatever and they drop almost all the way in. Hotter than ambient frame = expansion, colder than ambient = shrinkage
shrinkage on the small part + expansion on the head tube = trouble free install. a few wacks of the rubber mallet and it is IN
THE STABLE:
Kona coiler, Zion 737 29er (geared), Zion 737 SS ...
LOUD HUBS>>>SAVE BUBBS
Fox Stanchion Tube Replacement? Winger The Workshop 10 04-08-2008 08:29 AM
King of Kings? BSki General Discussion 51 02-06-2008 08:11 AM
Do I need a new headset? backcountryeti The Workshop 9 02-03-2008 11:57 AM
For Sale: STR headset caps SAR_boats The Market Place 26 11-12-2007 11:08 AM
Headset tools .8down The Workshop 30 11-09-2007 07:47 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75
