I know the regular answer but its not working. Shimano Centerlock rotor on Saint Hone hub with standard threaded axle. The axle seems to be the problem. My PARK tool for removing the lock ring on cassettes won't fit over the hub axle nut thingy. when I slide it over the axle, its short by maybe 1/4".
Is there a longer version of the park FR-5 lock ring tool or do it need to fully remove the threaded axle? maurice |
Longer or with a bigger/deeper whole drilled through it.
我是鄭偉倫
The Saint centerlock is slightly larger than the normal Shimano centerlock so your normal cassette tool won't work.
Shimano has a special tool for this - the LR20. http://www.jensonusa.com/store/produ...l.aspx?sc=FRGL |
Pho'dUp (05-07-2008)
| using non-shimano rotors on a shimano system? | pollu_sean | The Workshop | 10 | 04-15-2008 03:59 PM |
| Brake Rotors That Won't Bend | BrewMaster | The Workshop | 25 | 02-27-2008 07:54 PM |
| Quick Shimano Brake Lever question | Flat Broke | The Workshop | 3 | 08-03-2007 10:29 AM |
| Shimano Dual Control question | PacMan | General Discussion | 7 | 08-09-2006 08:01 AM |
| cover for when removing gear indicators on shimano shifters | royta | The Workshop | 14 | 06-23-2006 11:27 AM |
