Note the purple chainrig screws on my Stumpy! '90's baby!!
CeeDubb (05-06-2008)
Anyone remember these things? When I ride the bike now, my body bounces up and down with the cadence of the front rings. ![]() Don't think I want to be doing that on the SS. |
Creature of the Wheel
biopace?
all your macs are belong to us |
I think I'm going to convert my old HT into a SS as well, will I need to replace my 8 speed chain or remove links to make it work?
vincit qui patitur
You can use the same chain but you'll probably have to take some links out. However, you might just want to get a new chain. Get an cheap 8 speed SRAM chain.
Present suffering is not enjoyable, but life would be worth little without it. The difference between iron and steel is fire, but steel is worth all it costs. thebikesite.org |
the sram ss chain is cheap. i've heard the others will snap on you and whip your ballz, so i'd go with the ss chain.
jcampbl (05-06-2008)
Put MBenga in!
This is wrong. 8 speed chains work fine. Just get your chainline straight and you'll be fine.
I know the saying goes "Measure twice and cut once", but I prefer my method of "casually estimate once, cut once, and regret forever". -teamdicky |
el_d00der1n0 (05-06-2008),
i learnt if from foo
Put MBenga in!
That should be our stand by answer. Like my bad, I learned that from Foo.
Future Goater
Actually its the cassette that came with my rockhopper when I bought it in 04. I'm about ready to kick the $hit outta that cassette anyways because it keeps skipping on me when I try to hammer.
"He who throws mud loses ground." -Wise Old Man |
Put MBenga in!
Note, you'll need more than one old cassette to get enough spacers probably Jesse.
integradriv3r (05-06-2008)
The Flying Hawaiian
For the people converting older bikes the one thing I ran into with mine was that the 7 speed rear hub was a freewheel. You do not need spacers for this. Just run a bmx freewheel cog and you may need to redish the wheel.
Zonacat (05-06-2008)
That stumpjumper is a surprisingly strong steel frame, has a nice flex, and will climb like nothing else once you get that 6 pounds of old drive train off of there.
32:17 has suited me pretty well for a lot of the so cal trails. Remove the cassette, pick up some spacers and a cheap cog (most every shop has SS parts these days), and pick up a tensioner. Wider tires will help the thing to track a little better too. Only problem is too wide and you'll notice the frame rubs when climbing hard. It is kind of cool though to see how much the steel flexes - I was surprised. Thanks everyone on this post for getting me out of my secret interweb lurker life... I was so psyched to see another stumpjumper conversion that I had to post. I ride that thing as much as I can now, over any other bike I own. I'll post pics when I get back in town, I'm curious if anyone knows the production year anyway. |
Mashers Only !!
HUGH ![]() |
Future Goater
![]() ![]() ![]() Glad to see another lurker come out of the woodwork. As for my frame its an 04 Aluminum Rockhopper not steel. I bet my drivetrain right now does weight a ton but I still have heavy ass wheels so lightweight hardtail it is not. I'll be running 32:18 so hopefully that ratio will work out if not then ![]()
| Reba 29'er coil conversion ride report | DeeZee | The Workshop | 12 | 04-29-2008 03:23 PM |
| WANTED: Azonic Outlaw Conversion Kit | Dino Brown | The Market Place | 15 | 04-16-2008 07:40 AM |
| Vote tommorow | Rockinthecasbah | The Pub | 29 | 02-05-2008 07:32 PM |
| Cassette Question from a non-mechanic | Evil Chocula | The Workshop | 3 | 08-02-2007 02:10 PM |
| Sullivan Canyon Question | mdbradigan | Trailhead | 9 | 11-11-2006 10:21 PM |
