Old 05-04-2008, 08:27 PM   #1 (permalink)
BFloFoxRider.'s Avatar
Default BFlo Tests his young Electrical Skills
So, to make a long story short, I built my own mountain bike light, based off the Forums some others have posted on here... Ill just post pics of the processes, and if anyone would like to build one, i can help them or feel free to contact Lamba_Drive..
this rubberband is holding the switch that i epoxied onbefore soldering
after soldering
With shrink tubing
Holding on the handlebar mount i epoxied on...
A finished product
Total cost of the Light. . . . $18 and a few cents.
Thanks to Lamba_Drive for the help..
Brandon FLOres
BFloFoxRider. is offline
2wheel_lee (05-04-2008), bighit8 (05-04-2008), jeffj (05-04-2008), Lambda_drive (05-04-2008), roadkillross (05-04-2008)
Old 05-04-2008, 08:33 PM   #2 (permalink)
TURNERob's Avatar
Can we see some more pics.................................of the calendar j/k Good job! What kind of bulb did you use?
Uh hunk, yeah.
TURNERob is offline
BFloFoxRider. (05-04-2008), el_d00der1n0 (05-05-2008)
Old 05-04-2008, 08:34 PM   #3 (permalink)
MR16 50 watt Flood
i had to file the edges down so it would fit in the housing, though
Brandon FLOres
Old 05-04-2008, 08:35 PM   #4 (permalink)
λ_drive
Lambda_drive's Avatar
Glad to be of help.
Sweet looking light, and great going on making it for only $18.
Avatar: Great Horned Owl
Lambda_drive is offline
Old 05-04-2008, 08:38 PM   #5 (permalink)
Throw some Dee's on it
roadkillross's Avatar
nice brandon. thats one fat battery...
roadkillross is online now
Old 05-04-2008, 08:42 PM   #6 (permalink)
λ_drive
Originally Posted by BFloFoxRider. View Post
MR16 50 watt Flood
That's the same bulb I use for the Fully Loop, and it lights up the WHOLE trail.
Old 05-04-2008, 08:55 PM   #7 (permalink)
brandon you need to tin the wire before you solder, its a crimp connections so it should hold, good solder joints are shiny
otherwise it looks great and cheap!!(the best part)
BFloFoxRider. (05-04-2008), jeffj (05-04-2008)
Old 05-04-2008, 09:04 PM   #8 (permalink)
It was only my first time soldering.
Brandon FLOres
Old 05-04-2008, 09:10 PM   #9 (permalink)
Shu
Team Brittle
Shu's Avatar
If you haven't noticed yet the MR16 halogen bulbs get HOT....they will burn you...
07 Bionicon Golden Willow
Rat Rod cruiser
Shu is offline
BFloFoxRider. (05-04-2008), Lambda_drive (05-04-2008)
Old 05-04-2008, 09:11 PM   #10 (permalink)
This is true... very hot..
But, you just dont touch it...
Similar to a taser. What kind of person would touch it and Tase themself?
Brandon FLOres
Shu (05-04-2008)
Old 05-04-2008, 09:18 PM   #11 (permalink)
λ_drive
Yes, they get VERY hot, but when you're riding the air cools it down fairly well.
Old 05-04-2008, 09:20 PM   #12 (permalink)
Shu
Team Brittle
Shu's Avatar
Wasn't really refering to intentionally touching it but accidently bumping it....
Rat Rod cruiser
Shu is offline
Old 05-04-2008, 09:24 PM   #13 (permalink)
True True
I'll have to ride like the wind. Or attach one of those old school plastic things on a straw that spins if you blow in it. maybe itll act like a fan.
Orr try to remember not to bump it
Brandon FLOres
Lambda_drive (05-04-2008), Shu (05-04-2008)
Old 05-04-2008, 09:30 PM   #14 (permalink)
λ_drive
True True
It doesn't get THAT hot. Sure if you touch it it'll feel very hot, but it's not going to give you third degree burns or set nearby objects on fire.
Old 05-04-2008, 09:36 PM   #15 (permalink)
You have a cold solder joint on that connection. It will fail. Just a matter of time. Next time, tin the wire. Then crimp the crimp connection on, then solder.
92se-r is offline
BFloFoxRider. (05-04-2008), Chewyeti (05-06-2008), el_d00der1n0 (05-05-2008), Rockinthecasbah (05-04-2008)
Old 05-04-2008, 09:37 PM   #16 (permalink)
same thing I said
you didnt happen to race rc cars also ? lol
Old 05-04-2008, 09:37 PM   #17 (permalink)
next time ill post asking how to do that
or google it
Brandon FLOres
Old 05-04-2008, 09:39 PM   #18 (permalink)
you pretty much just heat up the wire on the top and suck the solder through the bottom until the wire is full of solder and shiny (tinned) dont worry you didnt build a rocket ship no one will die
Old 05-04-2008, 09:41 PM   #19 (permalink)
My light could blow a connection, short out and start a fire, and burn a house down or something
jk...
ok i get it... soi heat the top enough so you push the solder through the bottom..
oops i didnt even think of that
Brandon FLOres
