I have four month old Magura Marta SL's. About three weeks ago the front began losing power and over a couple of days I was gradually able to pull the lever all the way to the grip. There was no obvious leak and since I don't have a bleed kit yet I took it to my LBS. They bled it, but after a week the same thing happened. LBS re-bled. This time it worked find for two weeks. Just today I was thinking on my ride it was working great and my problem was solved. However, after cleaning the bike I now can pull the lever all the way to the grip again. Not the slow fade as the last two times, but great on the ride, nothing after cleaning.
No problems so far with the rear. I'm new to disk brakes. Any advice would be welcomed. |
iSlay
take it back to where you got it and ask for a new one...may be a bad o-ring or something inside the piece, causing it to lose pressure and fade?
5 Spot Frame for sale >>> http://www.socaltrailriders.org/foru...rf-cranks.html |
Yeah, assuming that it was properly bled, you probably have a bad master. Magura has a 5 year waranty, and in my experience, that waranty needs too much use. Check that your pads are not low. Martha brakes run out of fluid to push the pistons out more before the pads are all the way to the metal.
#4 (permalink) | |
Go Angels!
Charlie bit me
I'm running the same brakes. No problems with mine, but a friend told me he has had a similar experience just like yours. They warrantied them (rear), and all is good over a year later. Awesome brakes too.
If quizzes are quizzical, what are tests? “Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body—but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, ‘Wow, what a ride!’ ” —anon. |
Go Angels!
Couldn't tell about Maguras but on my Juicy-7's,if you squeeze the levers after the bike has been hanging by the front wheel,the brakes will be spongy and pull to the handgrips.After I set the bike back on two wheels,I squeeze the brakes a couple of times and everything goes back to normal.- Lloyd
un-kola (05-05-2008)
| Hayes Disc Brake 5" Rotor | BobBurnes | The Workshop | 6 | 02-25-2008 03:55 PM |
| Hydro brake bleeding, When? | JOx2 | The Workshop | 12 | 11-19-2007 08:29 PM |
| Hayes Brake Rotors & Pads | project_d | The Workshop | 10 | 10-17-2007 08:40 PM |
| Check your brake cables | UR2KLOS | General Discussion | 15 | 09-06-2007 11:28 PM |
| Brake lever pin missing | Paul000 | The Workshop | 4 | 08-07-2007 11:09 AM |
