Old 04-28-2008, 10:23 PM   #1 (permalink)
i ride bikes
Default How much spoke tension?
How do I know how tight to make my spokes? I can tell they need some tension but how much, I do not know. I think Dave from Adrenaline told me it was kinda just feeling it and knowing so this sort of leads me to believe I should have a pro do it.
I'm have access to a sh*tty truing stand that doesn't have have the self-centering 'hands' or whatever they are called and have a very basic idea of what to do but it doesn't seem that difficult.
Is it possible to permanently ruin my wheels by screwing up or can my shiesty truing job be remedied by a pro?
Thanks for any input.
ryandood is offline
Old 04-28-2008, 10:41 PM   #2 (permalink)
thats hot.
guero's Avatar
whatever you do, don't let jasonmason do it for you, i've witnessed him snap two spokes on two different rides. actually, one was before the ride even started!
tkBLAZER: i didn't ride with the bubbs back than, i was a steven
steppie: I plan on hitting it...
guero is offline
Dino Brown (04-29-2008), genusmtbkr5 (04-28-2008)
Old 04-28-2008, 10:43 PM   #3 (permalink)
genusmtbkr5's Avatar
Take it to a shop and let them do it or you will end up with wobble both up and down and side to side and they'll have to fix it anyway. Unless you have done it before or have a spare wheel to practice on, just let the pros do it.
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is offline
DirtymikeTDB (04-29-2008), ryandood (04-28-2008)
Old 04-28-2008, 10:43 PM   #4 (permalink)
Dirtbag
DirtymikeTDB's Avatar
Use a tension meter, it will depend on what type of spoke, round, aero, steel aluminum. double butted ETC.
DirtymikeTDB is offline
DBD (04-29-2008), ryandood (04-28-2008)
Old 04-28-2008, 11:39 PM   #5 (permalink)
Shit for brains
26'er Zen Master's Avatar
Ryan go into a shop. As you tension one spoke you pull another it is a tricky process and too much tension can severly ruin a wheel.
2 26" wheels one dark lord
DEUCE 6'ER LOCO'S FOR LIFE
2 in the pink 1 in the stink
Oh and I am kinda straight edge sort of.
26'er Zen Master is offline
DBD (04-29-2008), Dino Brown (04-29-2008), ryandood (04-29-2008)
Old 04-29-2008, 04:43 AM   #6 (permalink)
DBD
Old man goin' downhill
DBD's Avatar
If yer musically inclined you can tune by ear using the pitch of the spoke
Read here
Tunning by Pitch
It is a bit more difficult but doable
DBD is offline
el_d00der1n0 (04-29-2008), ryandood (04-29-2008)
Old 04-29-2008, 04:57 AM   #7 (permalink)
For me, it was helpful to have a known good wheel around. I compared the pitch to the one I was building. Don't twist too much -- maybe a quarter turn at a time, and apply the same turn all the way around ( use the stem hole as a marker).
According to Zinn, you're supposed to back out a little to let the spoke sort of normalize.
You'll have to get good at using the up and down feelers on your stand. To me, that's the hardest part to straighten. When you're working on the left and right, you loosen one side and tighten the other. Up and down, you loosen or tighten both sides to bring it down and up respectively.
Old 04-29-2008, 06:38 AM   #8 (permalink)
autoduel's Avatar
Keep in mind that thinner spokes require higher tensions. So apples to apples. Use the pitch to compare tension from spoke to spoke. Just like using a Y-wrench, you get a feel of how tight a nipple gets when twisting.
Steve
Just along for the ride
Originally Posted by SheDevil
Autoduel...yours is huge!!!
autoduel is offline
Old 04-29-2008, 09:04 AM   #9 (permalink)
There was a time whan I was quite proficient at tensioning wheels by tune. But that was when I was doing a lot of wheels regularly. I don't do as many wheels these days, and so lately I've been using a Park TM-1 spoke tension meter. Oh man, did I wish I had one of these back in the day!
http://parktool.com/products/detail....t=16&item=TM-1#
COLEKO (04-29-2008), DBD (04-29-2008), jschwart73 (04-29-2008), ryandood (04-29-2008)
Old 04-29-2008, 09:49 AM   #10 (permalink)
i ride bikes
It looks like I am going to have to bring my wheels into a shop, I'd rather not ruin my gear.
I've been meaning to bring my wheels in but everytime I call the shop you're not in. I'll just try again when I'm free.
Thanks for all the responses guys.
ryandood is offline
genusmtbkr5 (04-29-2008)
Im such a SS'ing monster I broke a spoke... foofighter General Discussion 18 03-23-2008 09:22 PM
Spoke recommendations for 175lb rider on 29er dubjay The Workshop 20 01-31-2008 08:12 PM
So I am A newbie bighit8 General Discussion 22 12-19-2007 08:55 AM
HELP - Wheel Failure Analysis RustyIron General Discussion 9 11-30-2007 09:14 AM
Spoke n' Wheel, West Hills Collette Bike Shop Reviews 2 08-06-2007 09:45 AM
