Old 04-27-2008, 04:01 PM   #1 (permalink)
GET FORMULA
jonathan_sykes81's Avatar
Default Bling-Bling SC Chameleon Mod Complete
So, I have had my beloved Chameleon for a little more than 3 years. There is only one thing that has always annoyed me about the frame, the worthless brake bosses on the seatstays. I personally have never had any use for them. Well, recently I got a new RFX and so the Chameleon has been put on the back burner as far as riding goes. I have planned on having it re-powdercoated and building it back up. I figured I'd lose those eyesores first though. I figure that you wont be able to tell they were ever there in the first place when I get it back from the painters. Here are the results from my playtime with the dremel:
UPDATE: Finally finished the media-blasting today. I had decided in the past few weeks that I was going to polish it instead of getting it powdercoated. I used the easiest, most painless process for polishing. I used plastic media for the blasting, this does no harm to the metal itself, it only removes the paint. After that I went over a few spots with 100grit sanding sponge, then 220grit on the whole frame, then coarse steel wool, then fine steel wool, then some Mother's Aluminum Polish and that's it. I probably only spent about 3 hrs sanding and polishing. As far as the brake bosses go, you can't tell they were ever there which is exactly what I wanted. All that left is to order up some new decals. Hope this helps someone and enjoy the pics. Later.
jonathan_sykes81 is offline
Alex (04-27-2008), amor587 (05-20-2008), art23rockpile (05-21-2008), bajamtnbkr (04-27-2008), BFloFoxRider. (04-27-2008), el_d00der1n0 (04-27-2008), ewiccami (05-20-2008), foofighter (04-27-2008), ghixon (04-27-2008), mtnbikerfred (05-20-2008)
Old 04-27-2008, 04:38 PM   #2 (permalink)
bajamtnbkr's Avatar
Looks good, is there a SS in your future?
bajamtnbkr is offline
jonathan_sykes81 (05-20-2008)
Old 04-27-2008, 04:42 PM   #3 (permalink)
GET FORMULA
It is a possibility, but most likely I will set it up just like I had it before but with updated components.
Old 04-27-2008, 05:13 PM   #4 (permalink)
An Illustrated Scumbag
J_Sims's Avatar
As long as you are having it painted you are good to go... Powder may be a challenge depending what you used as a filler. Powder is applied to metal that is magnetically charged and then cooked(think easy bake oven) many times fillers either do not allow the same amount of powder to be applied9less magnetic force to hold it in place) or there are heat issues. Go with paint and you will have no issues.
Or do not use a filler to smooth the grooves and powder should be great as well
That's right 1/2 Horse power baby
J_Sims is offline
Old 04-27-2008, 06:27 PM   #5 (permalink)
GET FORMULA
Originally Posted by J_Sims View Post
As long as you are having it painted you are good to go... Powder may be a challenge depending what you used as a filler. Or do not use a filler to smooth the grooves and powder should be great as well
I didn't use any filler and it is relatively smooth. I have only went over it with the cutting wheel and a really rough sanding barrel. I am still going to go over it some more to try and get it completely smooth. I honestly dont think you would be able to notice even if I left it the way it is but I am a slight perfectionist.
Old 05-20-2008, 09:50 PM   #6 (permalink)
GET FORMULA
Update
Old 05-20-2008, 09:56 PM   #7 (permalink)
Originally Posted by jonathan_sykes81 View Post
Update
Where's the update?
We want to see pics!!!
Old 05-20-2008, 09:58 PM   #8 (permalink)
mfoga's Avatar
Where's the update?
They are in the first post.
mfoga is offline
Old 05-20-2008, 09:58 PM   #9 (permalink)
Trail Surfer
amor587's Avatar
Damn, that looks really nice.... great job on the finish!
Yeti-ya-he-who!
http://www.travbuddy.com/widget_map_...php?id=3291361
amor587 is offline
Old 05-20-2008, 10:00 PM   #10 (permalink)
bajamtnbkr's Avatar
Nice job Daryl!
Old 05-20-2008, 10:00 PM   #11 (permalink)
Oh my bad. I just clicked on the link on the main forum page which takes me to the last post.
WOW!!! That is beautiful!!! I've been thinking about getting a polished Chameleon.
Old 05-20-2008, 10:03 PM   #12 (permalink)
www.zcbikes.com
ewiccami's Avatar
That is looking super bling-ing. Nice work indeed.
ewiccami is offline
Old 05-20-2008, 10:06 PM   #13 (permalink)
GET FORMULA
I think my favorite part of the whole thing is that I have ridden the SH!T out of this frame for almost 3 yrs and it now looks basically brand new. I can't wait to get it built back up and ride it again. I haven't ridden this bike since I got my RFX so I am looking forward to it. Also, I can't wait to take this to the BMX track, it is going to rip. Thanks for the compliments guys.
Old 05-20-2008, 10:37 PM   #14 (permalink)
Trail Jesus
integradriv3r's Avatar
Is this a steel frame? Looks bliiiiinggggggg!
Originally Posted by Pho'dUp View Post
I will have jacked your azz for mudd pies.
integradriv3r is offline
Old 05-20-2008, 10:52 PM   #15 (permalink)
GET FORMULA
Nope, it's aluminum. It is a 2005 Santa Cruz Chameleon, a do it all hardtail. I literally rode everything on this bike, for almost 3 yrs it was my only bike so I didn't really have a choice.
Old 05-21-2008, 12:29 PM   #16 (permalink)
Trail Jesus
If aluminum can look this nice you may have just given me an idea Might be time to strip the ole' Specialized.
Need your advice, Boss won't let me store my bike inside building. Fired Yo Momma General Discussion 45 04-11-2008 05:29 PM
Hayes Disc Brake 5" Rotor BobBurnes The Workshop 6 02-25-2008 03:55 PM
Hayes Brake Rotors & Pads project_d The Workshop 10 10-17-2007 08:40 PM
Check your brake cables UR2KLOS General Discussion 15 09-06-2007 11:28 PM
Brake lever pin missing Paul000 The Workshop 4 08-07-2007 11:09 AM
