Old 04-25-2008, 08:26 AM   #1 (permalink)
On the edge of chaos
Abui's Avatar
Default Checking chains for wear
I clean my chain often to keep the parts from wearing fast. I clean it with several rinses and shakes in a can of denatured alcohol.
Since it's off the bike I might as well check the wear.
Procedure (let gravity do the work of alignment)
(1) A 4-foot "yardstick" hanging on a nail.
(2) Hang the chain on a nail above the stick. Nail is set so a chain rivet lines up on an inch marker. A perfect chain would have a rivet exactly on each inch marker.
(3) Check the bottom end of the chain.
A picture of an almost new chain.
A picture of a worn-out chain. Not to be used.
Abui is offline
amor587 (04-25-2008), dubjay (04-25-2008), el_d00der1n0 (04-25-2008), jeffj (04-25-2008), Justin (04-25-2008), Pato (04-25-2008), Red Ryder (04-25-2008), wirk242 (04-25-2008)
Old 04-25-2008, 08:29 AM   #2 (permalink)
OMR
OMR's Avatar
Talking
those chain checker tools are really easy to use while the chain is still on the bike...
OMR .... An elder grasshopper of the Tribe
The journey is the thing .... ride like it's your last one...
OMR is offline
Old 04-25-2008, 08:33 AM   #3 (permalink)
Granny Ringer
silverspot's Avatar
... Or just get a chain wear indicator and check it while it's still on the bike.
silverspot is offline
onegymrat (04-25-2008)
Old 04-25-2008, 08:42 AM   #4 (permalink)
Abui's Avatar
Chain checkers don't measure the true pitch the teeth see, they can be fooled by wear between the rivets and rollers.
(If you clean often, checking is trivial)
Abui is offline
CHAINS!!!! AARRRGH!!! Has this ever happened to you? ChariotsOfTires The Workshop 71 07-18-2008 10:29 AM
A thread on chains UseItOrLooseIt The Workshop 16 04-07-2008 07:44 AM
DIRTTORPEEDO...MN girl checking in Noonerbean Introduce Yourself 12 02-07-2007 07:20 AM
Checking interest: STR Shirts LBmtb General Discussion 77 09-05-2006 08:51 PM
