Old 04-20-2008, 03:42 PM   #1 (permalink)
Default Thrashed Outer Ring on XTR M951, Replacement Options???
I am a nube to maintaining my MTB and have a XTR M951 Crankset with 46-34-24 rings and the outer ring have a few missing teeth. As is, it performs fine with only an occasional misfire and was wondering if I can just replace the outer ring or if I need to just buy a new crankset (ouch). If I can just replace the outer ring where do I get the part? Shimano, Ebay, Rock and Road? If I do need to replace the crankset I see some on ebay and was wondering if buying used stuff on ebay is too much of a gamble.
Jim
jimtc89 is offline
Old 04-20-2008, 05:05 PM   #2 (permalink)
Here's the challenge. The 951 cranks came with a couple chainring configurations: with a one piece chainring and spider (all have the middle ring mounting to it with four bolts - see the photo below) and there was a version that the outer chainring mounts to the spider (with five bolts).
If you have the one-piece chainring, good luck finding one in stock somewhere. Back when they were available, they were $100+. Hopefully you can find one on closeout. The ad where I found this photo, the middle ring is $79! They don't have the big ring. Unless you can find a good one for a good price, you may be better off getting new cranks or a buy a spider (The Path has some) and then a chainring (or rings, if you can only get one in a five bolt pattern).
If you have a five bolt removable chainring, your options are wide open to use any aftermarket chainring of the same bolt pattern. This will run you about $40 or so.
destroyer (04-21-2008), jimtc89 (04-20-2008)
Old 04-20-2008, 05:40 PM   #3 (permalink)
It Exists
Danimal's Avatar
If your interested in changing to an XTR 952 crankset, I have a set with a virtually new Bottom Bracket ( mabe 5 rides). Same gear ratio as the 951.
Very good condition, I'm willing to sell it....
Danimal is offline
Old 04-20-2008, 08:20 PM   #4 (permalink)
Well guess what I have the 4 bolt pattern so I guess i should start looking for a a new set.
jimtc89 is offline
Old 04-21-2008, 08:24 AM   #5 (permalink)
Today: Sally O'Malley
jeffj's Avatar
Says it's for a 952, but looks just like the one pictured:
http://www.jensonusa.com/store/produ...Chainring.aspx
Cambria has 'em too.
jeffj is online now
Old 04-21-2008, 08:57 AM   #6 (permalink)
http://www.jensonusa.com/store/product/CG309Z00-Shimano+Xtr+M952+Outer+Chainring.aspx
The one from Jenson will work. I pulled the photo from Cambria's site, and at that time, they only offered the small and middle ring.
jeffj (04-21-2008)
