Old 04-18-2008, 10:02 PM   #1 (permalink)
Default Problems with my Pike 454 air u turn
Does this sound familiar to anyone?
This is the second time I have had this problem.
On my fork if I have it fully extended to 140mm of travel if I compress the fork, either by just pushing on it or whatever, it sounds like there is air leaking out from under the adjuster knob. If I turn the knob 2 clicks down it no longer makes this sound. The kicker is that if I leave my bike on it's side overnight oil will leak out.
I had this problem before and R.S. sent me a new fork and I am having the same issue. FYI these forks have had less than 20-30 miles on them, mabye even less on the first one...
"It doesn't get any easier, you just go faster." Greg LeMond
schleppp is offline
Old 04-18-2008, 10:19 PM   #2 (permalink)
You mentioned that when you lean the bike on its side that oil comes out. Does it come out of the top adjuster? With the fork being angled, it would seem strange that oil would come out...unless it's being blow out through a leak.
I've had the same fork on my 4X bike, and I haven't had any problems or oddities with it.
If you don't want to wrench on it yourself (Rock Shox does have great service info on their webside), take it to a shop that is very capable with suspension. Or you could simply return it back to RS and get another fork.
2wheel_lee is online now
bighit8 (04-19-2008), schleppp (04-18-2008)
Old 04-18-2008, 10:24 PM   #3 (permalink)
Yes, the oil leaks out right below the travel adj. but only after some time. I had my bike in the trunk of my car over night and there it was when I went to get it out...
schleppp is offline
Old 04-19-2008, 08:12 AM   #4 (permalink)
There's a thread on MTBR about this.
I don't turn my bike upside down so I don't know if I have this problem. I'll check today and try the DIY fix if there's problems.
Found another thread on a different issue that might cause a leak.
So that's a possible small leak from each side of the fork... maybe I don't want to turn it upside down later.
bcblur is offline
Old 04-19-2008, 09:26 AM   #5 (permalink)
bighit8's Avatar
I have heard or read somewhere; that it is good from time to time to let the bike sit upside down.The purpose is to let oil reach some of the seals that normally dont get a lot of oil. It keeps them from getting dry.
DINO BROWN:I am a BIG fan of the G-Spot! You can quote me on that!
JASONMASON: Dude you didn't get lost...Thats where the trail ends!!!!
bighit8 is online now
BFloFoxRider. (04-19-2008)
Old 04-19-2008, 09:31 AM   #6 (permalink)
TURNERob's Avatar
There is an o-ring underneath the u-turn adjustment knob that rotates everytime you use the u-turn knob. This o-ring eventually gets flattened out and will let oil seep by. It is a pretty easy fix. Just take the u-turn knob off by removing the c-clip, then take the top nut off and the top portion of the u-turn mechanism will come out and you will see the o-ring on the shaft. I just went to a hardware store and got a new o-ring and problem solved. You don't have to drain the oil out or anything....pretty simple fix.
Uh hunk, yeah.
TURNERob is offline
bighit8 (04-19-2008), Ladd Jasper (04-19-2008)
Old 04-19-2008, 02:23 PM   #7 (permalink)
Cereal Spilla'
Ladd Jasper's Avatar
I've performed this fix a couple times myself, and as Rob mentioned, it's pretty quick and very simple.
I'd add that you'll want to be extra careful when removing the U-Turn cap, as there are several tiny ball bearings and springs underneath that allow the knob to index properly (those clicks you hear when it's turned), and keep it from moving on its own. If you go tearing in there, those tiny buggers will scatter like roaches in sunlight and you'll be searching for days trying to find them all.
Yes, I speak from experience
jfsh: You do the wall ride for fun, not for pictures. The photos are just an added bonus.
RacinJason: But what can they do take urine tests D&A samples?
Ladd Jasper is offline
TURNERob (04-19-2008)
Trailwork on Silverado MW genusmtbkr5 Trail Conditions 17 04-22-2008 07:14 AM
I've got problems PacMan General Discussion 48 11-30-2007 08:29 AM
For those that aren't aware... Innes General Discussion 0 11-28-2006 09:55 AM
Tour Dela El Taaacooooe Nnnnaaaazzzoooooe dirttorpeedo Trailhead 54 08-17-2006 11:58 AM
RS Pike Team fork for sale! TURNERob The Market Place 24 09-19-2005 11:27 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84
