Old 04-17-2008, 02:47 PM   #1 (permalink)
XC not DH for me
Default SS question
On the rear wheel is there a spacer that I put in? No matter how hard I clamp the tire in the wheel wants to scoot up. It is a brand new wheel so it isnt stripped and it is my first single speed so please bear with me.
Thanks
Pics For Clicks:
PassatBoy101 is offline
Old 04-17-2008, 02:57 PM   #2 (permalink)
Au575's Avatar
To quote Sheldon Brown (RIP):
Conventional wisdom is that you need a solid (nutted or "bolt-on") axle hub for fixed-gear or singlespeed use, and that a quick-release will not hold the wheel solidly enough in a horizontal fork end. This is not true, however.
Since most newer bikes have vertical dropouts, people have gotten used to wimpy aluminum skewers, and often don't adjust them as tightly as they might.
If you use a good quality (Shimano is the best) skewer , tightened securely, it will hold just fine in any type of dropout or fork end .
http://www.sheldonbrown.com/singlespeed.html
But you might find that even with max tension on your skewers, you need chain tugs. Check some out here:
http://www.bikemannetwork.com/biking/c/COMPCHTSS
Au575 is offline
genusmtbkr5 (04-17-2008), PassatBoy101 (04-17-2008)
Old 04-17-2008, 02:58 PM   #3 (permalink)
Geddyup!
CPATCRASH's Avatar
First try filing the paint off the dropouts and make sure there is a washer in there. If that doesn't work go get a surly chain tensioner.
Cowboy.
CPATCRASH is offline
Au575 (04-17-2008), HELLDOG (04-17-2008), PassatBoy101 (04-17-2008)
Old 04-17-2008, 02:59 PM   #4 (permalink)
dirt ninja
thebush's Avatar
Are you talking about the sliders moving forward in the horizontal dropouts?
thebush is offline
Old 04-17-2008, 03:02 PM   #5 (permalink)
HELLDOG's Avatar
Default Highly Recommend
I have used this chain tensioner on two SS now,Works Great! The best part is the bottle opener.
HELLDOG is offline
CPATCRASH (04-17-2008)
Old 04-17-2008, 03:04 PM   #6 (permalink)
Geddyup!
CPATCRASH's Avatar
For sure! If you get sick of your wheel sliding you can just give up and open a beer!
Cowboy.
Old 04-17-2008, 03:07 PM   #7 (permalink)
Small, but Mighty
Zippy's Avatar
I didn't realize the detail work doubles as a bottle opener. Sick! Almost makes me sad I have an eccentric BB. Almost...
L8 APEKS: "Never underestimate the power of stupid people in large groups."
Swim, bike, run.
www.zippyathlete.blogspot.com
Zippy is offline
Old 04-17-2008, 03:39 PM   #8 (permalink)
HELLDOG's Avatar
Oh Yeaaaa!!... Just one of many reasons to pop one open.
HELLDOG is offline
Old 04-17-2008, 03:43 PM   #9 (permalink)
One of the next challenges you may face even if you have a tensioner is just the opposite problem on the brake side, especially with those big binders you have on there.
With horizontal dropouts, the drive side gets pulled forward, and because of braking forces, the brake side of the rear wheel can move backward. The tensioner can't help that.
Make sure you have a death grip when you're tightening that skewer! Another option is to convert the rear hub to a bolt-on, and ditch the QR.
Old 04-17-2008, 03:52 PM   #10 (permalink)
XC not DH for me
It is a horizontal drop out. I called my friend and he said something about an allen bolt that I need to tighten.
thebush (04-17-2008)
Old 04-17-2008, 06:24 PM   #11 (permalink)
dirt ninja
thebush's Avatar
Yup. I have the Monocog Flight and I believe it uses the same sliders as your Monocog.
EDIT: Now that I look closer they look different.
thebush is offline
Old 04-17-2008, 06:36 PM   #12 (permalink)
XC not DH for me
Whats that Black drop thing?
Vote tommorow Rockinthecasbah The Pub 29 02-05-2008 07:33 PM
Frame sizing question... Jman The Workshop 9 11-25-2007 06:36 PM
Rear hub question... gurp13 The Workshop 21 11-12-2007 08:50 AM
Question about Mavic rims... kind of a tech question Stray_Bullit General Discussion 4 12-03-2006 01:48 PM
Sullivan Canyon Question mdbradigan Trailhead 9 11-11-2006 10:22 PM
