Rolling on 29" dubs!
how much do you weigh?
i am 165-170 with gear and ran my rear sb8 at about 32 psi (with a tube).
"forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle |
XCMike (04-17-2008)
I run 30 psi up front and 32 psi in the back. Keep in mind though that this is on a tubeless setup. I am using the 2.55 weirwolf lt up front and a 2.35 rampage in the back. Becuase the SB8 has less volume I would think you would have to run it a tad higher....closer to 35 psi would probably be good.
What type of riding do you do? Tech ST or mostly fireroad? |
XCMike (04-17-2008)
I've run the SB8's front and back at 30-32 if it's a bit rocky.... add more sand and I'll run them lower at 26-28. I run the Neves at 22-26 depending on conditions.... play around with the pressures as the trail conditions changes.
PS: I weigh in at 150 and tend to ride very light.
OMR .... An elder grasshopper of the TribeThe journey is the thing .... ride like it's your last one... |
XCMike (04-17-2008)
Duan'er - 29'er remixed
i run 30psi but i'm tubed...i get great great traction knock wood hope i dont get pinch flat
XCMike (04-17-2008)
I've run them from 30 to 45 psi with a tube and the sidewalls feel flimsy no matter what pressure I run. I can feel them roll over on tight turns or on fast rocky sections.
I'd rather be climbing...
Brew, that's not the tires. It's your bike's automatic mudhole-seeking feature. ![]()
Climbing *is* its own reward! It's obvious I'm not a weight-weenie; I ride a Kona!
Friends don't let friends ride Small Block 8s in the San Gabriels.
This is the trail that I have ridden many times. I got lazy and did not take the SB off the rear after a slickrock trip. SB's braking power has much to be desired in decomposed granite...so into the water I went. They are OK on the OC dirt, never again in the SBs. Dean
XCMike (04-18-2008)
| Question #1 for the hardcore 29er group | XCMike | General Discussion | 95 | 04-03-2008 07:50 PM |
| Vote tommorow | Rockinthecasbah | The Pub | 29 | 02-05-2008 07:33 PM |
| Medium Voodoo Aizan Scandium 29er 3.5lbs and other 29er stuff | duke777 | The Market Place | 3 | 12-11-2007 08:45 AM |
| a 29'er question | new2mtb | General Discussion | 60 | 08-15-2006 12:19 PM |
| 29'er tire compatibility question | EndoMaster | The Workshop | 8 | 05-10-2006 08:01 AM |
