Old 04-16-2008, 01:49 PM   #1 (permalink)
HBeric's Avatar
Default Servicing Mavic Crossmax SL Hubs (2006)
I think I may need to service my 2006 Mavic Crossmax SL hubs. While riding recently, I noticed an abnormal howling noise that was coming from one of my wheels while coasting/braking at medium to high speeds. The howling did not occur while pedaling. I also think that there may be a very slight amount of play in the cranks when going from not pedaling to pedaling - this is very slight (probably less than 1/4 of a centimeter), but it is as if something is not engaging as quick as it should.
Do you think that these issues are related to my hubs needing a service? I bought the wheels about a year and a half ago, but since I have a couple other sets, they probably have less than 500 miles on them.
If it is a service issue, do I need the front and rear serviced, or just the rear? I'd love to hear from someone who is familiar with this wheelset
and with servicing it. Today, I bought the freehub/pall/bearing kit just in case I need to do more than just a cleaning and lube.
Thank you in advance,
Eric
HBeric is offline
Old 04-16-2008, 02:01 PM   #2 (permalink)
Hecho en Japon
freekengo's Avatar
Eric
Really carefully check the spindle side of the hub. Make sure that there are no grooves cut into the spindle side of the hub. If there is, you are ready for a new hub. Otherwise, the problem will repeat relatively soon. Also check the white bushing that is pressed into the freehub body to make sure that there are no visible contaminants, or grittyness to it. Believe me, I found this out the hard way.... Good Luck!
freekengo is offline
HBeric (04-17-2008)
Old 04-16-2008, 02:02 PM   #3 (permalink)
I am familiar with the howling noise. Your rear hub needs service. Check for play and roughness in the axles. If they are smooth and tight, I would just proceed with servicing the rear hub.
thephat is online now
HBeric (04-17-2008)
Old 04-16-2008, 02:04 PM   #4 (permalink)
jschwart73's Avatar
http://roguemechanic.typepad.com/rog...echanic-m.html
http://roguemechanic.typepad.com/rog...echanic-1.html
Check for horizontal play in the cassette/freehub, that's indicative of the seal going south.
I've had good luck using Phil Wood Tenacious Oil to lube the ratchet/pawl and freehub seal. Mavic recommends Mineral Oil, but IMO it's way too thin. It does cause the freehub to drag a bit more, but I'll take a little extra drag for the increased longevity - My SL's have about 300 miles on them and the freehub seal looks brand new still.
Toy Cars and Mountain Bikes
Coming Soon - MTBPics.net - A MTB Video and Photo Archive destination
jschwart73 is offline
HBeric (04-17-2008)
Old 04-16-2008, 02:31 PM   #5 (permalink)
You might also want to check your bearings while you are at it. Just open up the orange or black seals with a sharp thin knife, clean and put new grease into the sealed bearings. There are 2 for the front, and 3 for the rear I believe.
By the way, where did you get the freehub kit?
Cableguy is offline
HBeric (04-17-2008)
Old 04-16-2008, 03:04 PM   #6 (permalink)
HBeric's Avatar
Thank you for the responses so far. I watched the video and it looks like a fairly easy repair.
I have horizontal play when I wiggle my cassette on the sides, but nowhere near as much as I see in the video. Mine wiggles maybe 1 mm each way. Is this enough to justify replacing the freehub?
Also, I didn't hear the rogue mechanic say anything about replacing the bearings on the hub shaft (nose). Are those items something that you don't replace every time you replace the freehub?
Eric
HBeric is offline
Old 04-16-2008, 03:29 PM   #7 (permalink)
Professional Lion Tamer
Keith B's Avatar
That also happened to my 06 SL's. Had a new freehub body. Bearings also recently seized (all of this on the rear wheel btw) and replaced. Not so bad considering the mileage I put on them.
"I once met three guys named pain, suffering and sacrifice. Now, we're inseperable. We're best friends"
Keith B is offline
HBeric (04-17-2008)
Old 04-16-2008, 04:38 PM   #8 (permalink)
nintense's Avatar
Default Simple service usually solve the problem.
You may need also a freehub bearing for the howling.
If you in LA, you can stop by for quick on spot service.
Eric
nintense is offline
HBeric (04-17-2008)
Old 04-17-2008, 09:11 AM   #9 (permalink)
HBeric's Avatar
Thank you everyone for the great information.
I opened up my rear hub last night and cleaned/relubed all of the parts. I even repacked the drive-side bearing, as one of you suggested. I left the non-drive-side bearing alone, as I wasn't sure how tight to tighten the cap after reinstallation (I have read that if you over tighten, you can blow out the bearings).
The freehub assembly and hub area had some dirty and grime in it, but it really wasn't that bad. The inside of the drive-side bearing was very clean, but I added some grease to it, as it looked a little bit low.
I'll give it a ride tonight and see how things go. If I get the howl again, I plan to replace the freehub, pawls, springs and both hub bearings (the third bearing the people mention is included in the freehub).
As far as casette wiggle, it is wiggling a tiny bit, but it is nowhere close to what that cassette was doing in the rogue mechanic video. It probably moves back and forth 1/2 to 1 mm. I compared it to two of my other bikes:
My very high-mileage Specialized S-works hub with XTR cassette - very, very solid with zero wiggle
A SRAM cassette on a set of low-mileage Mavic Crossride wheels - about half of the wiggle that my Crossmax SL setup currently has.
Eric
HBeric is offline
Old 04-17-2008, 09:25 AM   #10 (permalink)
Eric,
My cassette/freehub doesn't wiggle at all. Are you sure its the freehub and not the cassette that is worn down? You might want to try another or new cassette to see if it wiggles before replacing it.
The manual says that you should tighten the bearings to handtight, and then 1/4 turn the other way. You need to do this with the QR already tightened.
Cableguy is offline
jschwart73 (04-17-2008)
Why Are Expensive Hubs Noisy Hubs? Waldo The Workshop 41 02-12-2008 03:48 PM
Mavic Crossmax SL Disc Wheelset TucknRoll The Market Place 3 10-03-2007 09:37 PM
Anyone have experience w/ Mavic crossmax enduro's lukewiens The Market Place 8 05-22-2007 12:27 PM
