Team Brittle
I have an 06 Rockshox Rev"E"l"A"tion and tonight I was checking the air pressure...in the lower left stancion..I decided to let a little out and what comes out yellow-ish oil....this is not good correct? It rode fine before and after...
What caused this and what do I need to do....if anything The air pressure was 125ish on both top and bottom....
nintense (04-15-2008)
Duan'er - 29'er remixed
i've experienced that w/ my revelation fork havent had a problem
Shu (04-15-2008)
That happens with my Reba, was told some oil gets by the seals...some oil is normal. What did surprise me when I did the Pike conversion the foam seals where totally dry. Reba only 7 months old, and since I have four bikes none of them see that much use.
Shu (04-15-2008)
JOx2 (04-15-2008)
here you go jojo
JOx2 (04-15-2008)
And very common in an air forks / shocks.
And it's Revelation, not Revolution ![]() ![]() Quote:
Shu (04-16-2008)
Team Brittle
I peeled the stickers off before I got the bike home
![]() Never looked at the name that close and got most of the letter correct![]() ![]()
nintense (04-17-2008),
RacinJason (04-25-2008)
tk |
Chewyeti (04-25-2008)
You can replace the oil lost by letting out all of the air then removing the V stem then draining the oil and re fill with the recommended CC's of fluid. You can buy at most shops. Just tell them what you are doing. My fork spits up a little when I let air out. Both my Totem and my Reba. Both still work fine.
| question about front fork | Roadstar_Rider | General Discussion | 21 | 04-16-2008 10:19 AM |
| Reba questions | traumadiver | The Workshop | 8 | 02-25-2008 02:04 PM |
| Fork Question... | Jman | The Workshop | 13 | 02-05-2008 09:15 PM |
| fork question | number7s | The Workshop | 1 | 02-05-2008 10:23 AM |
| Fork upgrade question | 0gravity | The Workshop | 13 | 05-23-2007 11:17 PM |
