one wheel drive
Just blew out my rear deore hub on my crappy OEM wheelset...so i figure i will order a set of XT wheels (from JensenUSA it is an amazing deal at 145 a set)...
the old deore hubs take the shimano center lock style discs, so I can't swap over the rotors from that set. so the question is, can i run other rotors? hayes, etc? or do i have to buy the shimano 6 bolt dealeos? ![]()
Heckler |
You can run other rotors as long as they are the correct diameter. I think Shimano makes some of the best rotors.
That Deore hub can be fixed, and those OE XT hubs are not noticeably better than the Deore hubs you have. If it is a blown freehub, that is about a $30 part. I think center lock is better than 6 bolt. |
pollu_sean (04-14-2008)
one wheel drive
well, i really thrashed the rear hub...didn't do much maintenance on it, so i actually seized it. oops. i could replace the hub i guess and get the wheel rebuilt but for that price i can basically get a new set of the xts. from what i read the hubs feel similar but the seals are better on the xt's, thus giving them a longer life...
yeah i like the center lock discs, so easy to get on and off. just seems like hubs with the center lock mount are hard to come by except on the xtr sets.
Heckler |
If you're hearing too much noise with the metallic pads, try swapping them out to the resin pads. They may not perform as well as the metallics on long DHs, but they're said to be quieter.
Piranha (04-14-2008)
1. Less work to take on and off.
2. Less threaded bolt holes equal less opportunity to destroy the hub. 3. I kind of think you save weight if all else is the same. 4. cleaner look. Quote:
one wheel drive
50$ parts and labor, who's this we you speak of?
Heckler |
#10 (permalink) | |
Thanks |
one wheel drive
thanks for the suggestion...i really appreciate it. i don't come down Tustin way very often so doing the 30 plus miles each way 2 times probably won't happen but maybe i will try my LBS to see what they say... at the very least if i replace the rear wheel i will definitely get this one fixed so that i have a backup.
Heckler |
thephat (04-15-2008)
| New Dura Ace 7900 | Rob | The Roadie Hangout | 11 | 06-11-2008 08:44 AM |
| Post pics of your bike(s) | racer1337 | General Discussion | 301 | 03-03-2008 08:44 PM |
| Brake Rotors That Won't Bend | BrewMaster | The Workshop | 25 | 02-27-2008 07:55 PM |
| Shimano American Buys Pearl iZumi for $70M | Kid A | General Discussion | 11 | 02-19-2008 08:41 PM |
