I just stripped not one but two rotor bolt holes. Is there a way to save my hub?
RacinJason (04-13-2008)
#2 (permalink) | |
chupacabra (04-13-2008)
It can be fixed. Do you have a Dremel tool?
You can cut a slot and use a screw driver. I have done that mamy times. You must use a high quality flat head screw driver it must have a hex at the base by the handle to give you more leverage. Use one hand to push down and the other to twist the wrench. I have also used the sears easy out kit. |
Considering how many people run only 3 of their 6 bolts, presumably to save weight, if you can't fix it, I'd just continue to use it.
In worst case drill it out a little bigger and use a heli-coil.
singletrack angel: is that a real hole Fred? Mtbnbikefred: Yes,I have stuck all kind of things in it. |
Geddyup!
Just take the rotor off! You will go WAY faster!
Cowboy. http://www.thepathbikeshop.com/ Daily thought: some people are like slinkies - not really good for anything but they bring a smile to your face when pushed down the stairs! |
chase the threads first.... (get a tap.. and try to clean them up)
worst case drill it one size bigger, and helicoil/timesert or rethread it bigger
-Aaron or Chewy VOODOO Canzo 29er "Dude, this brings back memories of the gay bar I went to!" - Rockinthecasbah |
bighit8 (04-13-2008),
Geddyup!
All kidding aside. Some racer types only use three bolts per rotor.
#12 (permalink) | |
It is possible. I think I'm going to try the helicoil thing first. I've also looked at the timesert products. I'm hoping that I can use the same bolts as before. It seems like a cleaner setup. If someone has had experience with the helicoil or the timesert, advice would be apprecaited.
Not sure on that rusty( through bolting), might weaken the hub.But, McFadden Dales in orange and Anaheim have all the right threads/pitch/length he would need.Just dont use grade 8.
For some reason I thought you stripped out the head.
OPPS Sorry about that.I would just use 3 bolts like a lot of people have mentioned. That is what i have on my single speed it works fine. |
#19 (permalink) | |
![]() Not using all the bolt holes will damage the rotor and hub. The current design was intentionally planned that way so the forces involved in braking were shared evenly over the face of the hub, the bolts, and rotor. ![]() Drilling the hub will weaken the hub structure as well. I'd use that as a second to last resort. If the bolt can't be tapped out, buy a new hub. You'll thank youself later. Using only three bolts.... I heard that if you take out the QR's holding your wheels on that really save you some weight. ![]()
"Inaction is a weapon of mass destruction." -Faithless "Mass Destruction" 2004
Sorry about that.
