#22 (permalink) |
I'm a big fan of timeserts. If I recall correctly, you can even find those in metric sizing at some Pep Boys! I'm not sure about that small, though.
Did you trash two holes right next to each other?
#24 (permalink) |
Heli-coils are your best bet. An easier fix is Loctite "Form A Thread"
http://tds.loctite.com/tds5/docs/81668-EN.PDF |
chupacabra (04-13-2008)
#25 (permalink) | |
thanks all |
#26 (permalink) | |
Steve Peat Wannabe
I took a DH clinic with Eric Carter & Rich Houseman a few years ago. I noticed that EC was running only 3 rotor bolts; I asked him why and he said, "3 bolts holds the rotor just as good as 6." Since then, I've been running 4 rotor bolts on my SC Nomad as well as my Intense M3. I've had ZERO problems !So...don't bother fixing it, instead, take one or two more out and lose some grams!!! |
#27 (permalink) | |
If a locking nut will fit between the bolt flange and the hub shell, get a longer grip bolt, superglue the nut to the wrench to hold it in place for a minute, and torque it up. I've had bad luck with the locking feature on helicoils. The Timesert looks cool except for the flange, though you could file that off before insertion. If the flange is Aluminum and the timesert is steel, you'll want to goop up the outside of the insert with primer to inhibit corrosion. |
#28 (permalink) |
Hey Bob hows it goin? Yeah I though the same thing for a long time then I noticed a load of people using 3-4 bolt combo's All of the guys that I noticed doin it where Expert XC guys. For 4X and DH wouldnt think of it.
I set my SS bike up that way and it works fine. |
#29 (permalink) | |
"Inaction is a weapon of mass destruction." -Faithless "Mass Destruction" 2004
bighit8 (04-14-2008)
#30 (permalink) |
heli coils are not the best option...there are better ways to replace/rethread a part depending on how much space or metal you have to work with.....go online to McMaster-Carr and look up thread repair...basically you drill/tap a larger diameter hole,tap it out and thread in the insert....key it in if you get the high strength permanent locking type and then insert your original bolt -it can actually end up much stronger than the original configuration if you have enough metal around the hole.
Allen |
#32 (permalink) |
A lot of DH racers run 3 rotor rotor bolts for easy wheel changes. I don't think it's for the gram savings.
Keep an eye on em. As mentioned before, they should at least form a triangle. |
bighit8 (04-14-2008),
RacinJason (04-14-2008)
#35 (permalink) | |
Team Brittle
~You can't fly forever without getting killed, what a way to go! ~The three best things in life are a good landing, a good orgasm, and, a good bowel movement. The night carrier landing is one of the few opportunities in life where you get to experience all three at the same time.
#37 (permalink) |
White industries. I was using my drill motor to put install bolts.
I just finished retaping the hole and using a new bolts. It seems that it may have fixed the problem, although I am leery to torque them down. I'll leave them like that and see if they loosen up. |
HELLDOG (04-15-2008)
#38 (permalink) |
Shrek must be destroyed
yup... that'll kill it. (drill motor that is)
chupacabra (04-14-2008)
#39 (permalink) |
Yeah,
It's a lesson I once had to learn. Don't use a drill to turn your rotor bolts unless you back off the speed and or back off the torque a lot. |
chupacabra (04-15-2008)
| Tiny hole in bite valve | ryandood | The Workshop | 2 | |
