#21 (permalink) |
Don't taze me bro
I have shimano rotors, XT SM-R75S, that was what took me so long to put them on the bike. I accidently bought center lock but I needed bolt on (anyone need some 160mm center lock rotors)
el_d00der1no I busted a nut MTBMaven The salty flavor really hit the spot. |
#22 (permalink) | |
You used mineral oil when you cut and bled them the first time, right?
Toy Cars and Mountain Bikes Coming Soon - MTBPics.net - A MTB Video and Photo Archive destination |
emfc (04-15-2008)
#23 (permalink) | |
I've installed and bled many hydraulic brakes, and so I have some familiarity with different types. However, I haven't worked on Shimano brakes since their 4-pots back in 2002 or so. Last night, I installed a set of the 08 XTs onto my Mob (I also have a set for my SlopeStyle). Admittedly, it was a bit challenging bleeding them for the first time. It was seriously an exercise of patience. Once you think you have all of the bubbles, you've only just begun - you probably have a lot more. After that, once you think you're done, keep going, you'll get more bubbles out. If I can offer one additional tip, don't be stingy with the fluid. Expect to run nearly a full bottle of fluid through the brake (if your drain canister is clean, you can reuse it). The levers on my brakes are rock hard. ![]()
b5driver (04-17-2008),
Cableguy (04-17-2008),
JoeTruth (04-17-2008),
Marshall Willanholly (04-17-2008)
#24 (permalink) |
I should also add that my brakes did not come as a prebled kit. They were bought as individual components, so there was never any fluid in them, which can make the bleed process a bit more difficult.
| Disc Brakes Installation | wgb | The Workshop | 4 | 04-07-2008 06:38 PM |
| MMM...Brakes | Red Hot Sloth | The Workshop | 51 | 01-31-2008 08:51 AM |
| Fontana Raffle Prize - Stroker Brakes | aukmal | General Discussion | 2 | 11-21-2007 09:32 AM |
| Bleeding Hayes Brakes | project_d | The Workshop | 10 | 10-22-2007 11:16 PM |
| Cable disc brakes. | sandblast | The Workshop | 22 | 09-11-2007 02:26 PM |
