Old 04-10-2008, 12:30 PM   #1 (permalink)
Or Not Enough
TooManyTacos's Avatar
Default Pike Coil spring rate when travel is reduced
I had a Pike Coil U-Turn on my big bike, but got a sick deal on a Dual Air, so the Coil is going on my 100mm travel bike so I can take advantage of the 20mm axle. Does the spring rate or compression change when the travel is wound down from 140mm to 100?
TooManyTacos is offline
Old 04-10-2008, 12:35 PM   #2 (permalink)
Yes, as you lower the fork, the coil spring gets stiffer.
See page 6 http://www.sram.com/_media/techdocs/07%20PikeRebaRevelationDomainArgyle.pdf under Coil Spring Tuning.
TooManyTacos (04-10-2008)
Old 04-10-2008, 12:40 PM   #3 (permalink)
Or Not Enough
Thanks, good to know!
Old 04-10-2008, 02:02 PM   #4 (permalink)
F = KX
F = force of the spring
K = spring coefficient
X = deviation (distance) from natural at rest spring length
so yes... squished spring = more force
Big Boys ride.....BIG wheels.
Chewyeti is offline
Old 04-10-2008, 02:14 PM   #5 (permalink)
F = KX
The U-Turn system does not squish the spring. It is not a preload mechanism.
Instead of using the full length of the spring, the U-Turn adjustment mechanism essentially engages the spring somewhere in the middle, rather than at the ends when the fork is at full height. So because you're compressing a shorter length of the same spring, the spring rate is higher.
autoduel (04-10-2008), carbonman (04-10-2008), Chewyeti (04-10-2008), Rockinthecasbah (04-10-2008)
Old 04-10-2008, 02:21 PM   #6 (permalink)
oh that makes sense... good to know
Chewyeti is offline
PIKE COIL U-TURN $250!! Silver in color DISCO The Market Place 18 04-15-2008 09:30 AM
Spring Rate question Lor The Workshop 6 03-05-2008 07:50 PM
Fox vanilla coil spring 550 lb x 2.25 tkblazer The Market Place 9 03-11-2007 06:29 PM
