Old 04-09-2008, 05:04 PM   #1 (permalink)
Macross Frontier
RS VR6's Avatar
Default Hayes 22mm rear caliper and/or adapter??
I've got a Homegrown that is a small. The rear triangle is super tight. I want to run a disc in the rear. I've seen the A2Z one...but I know that one won't work.
Has anyone seen this? http://cgi.ebay.com/ws/eBayISAPI.dll...link:middle:us
Maybe this one?
http://www.chainreactioncycles.com/M...?ModelID=20557
Did all the Hayes 22mm mount in the same place?
Anyone have an old Hayes laying around?
Thanks
-Lee
RS VR6 is offline
Old 04-11-2008, 11:24 PM   #2 (permalink)
Macross Frontier
RS VR6's Avatar
Someone offered me one for 40 shipped. Is that a good deal?
"Its been sitting with the 2 halves apart for awhile, but was never used. I think I stole the center o-ring out of it to rebuild one of my other calipers."
I don't know anything about this particular caliper.
RS VR6 is offline
Old 04-11-2008, 11:27 PM   #3 (permalink)
GET FORMULA
jonathan_sykes81's Avatar
How about this? http://www.chainreactioncycles.com/M...?ModelID=20557
I used to have a frame with the 22mm mounting and I just ran v-brakes in the rear.
jonathan_sykes81 is online now
RS VR6 (04-12-2008)
Old 04-11-2008, 11:43 PM   #4 (permalink)
I think I have a Hayes 22mm caliper at my father's house. I'll try to make it by there this weekend. If I remember, it actually may be brand new, or close to new.
RS VR6 (04-12-2008)
Old 04-12-2008, 12:34 AM   #5 (permalink)
Macross Frontier
RS VR6's Avatar
I just might end up keeping the V brake in the rear. I have the combo XT/brake lever setup. That means I have to get a new shifter and brake lever. I have BB7's in the front now. I'm going to end up with Franken-brakes.
I don't think that adapter from Chain Reaction is going to work. The rear triangle is super tight...the caliper is going hit the seatstay.
Here is my rear tri...will this work?
RS VR6 is offline
Old 04-12-2008, 07:39 PM   #6 (permalink)
Bike Industry Slave
biglimey's Avatar
All the 22mm's mounted in the same spot in relation to the rotor. I think that QBP still has the parts so that you could build up a 22mm caliper.... that way you could get a used set of hayes mags, and just replace the 74mm caliper half with a 22mm half.
just a thought...
biglimey is offline
RS VR6 (04-12-2008)
Old 04-12-2008, 11:01 PM   #7 (permalink)
Macross Frontier
RS VR6's Avatar
Any links? I'm still a noob...
RS VR6 is offline
Old 04-13-2008, 03:38 PM   #8 (permalink)
Bike Industry Slave
biglimey's Avatar
couldn't find the parts on the QBP site, but I did find this -
AD- PMR Features/Benefits: Adapter for parallel disc mount of Trek, Klein, Jamis...to convert to international standards disc mount Enlarge your rotor diameter 20 to 25mm for increased more braking power! Weight: 45g
http://www.a2zcomponents.com/OLD-web/Adapter/adap01.htm
may be a better choice as this way you could use a 74mm cable actuated disc instead!
biglimey is offline
Old 04-13-2008, 03:54 PM   #9 (permalink)
your hero
Gabriel Zink's Avatar
Default A2Z is Crappy
Go to Adrenaline Bikes and have Neil get you a Hayes Caliper, from Hayes. This will fit your frame with no adaptor. The A2Z adaptor is crappy and will give you problems. If you do not have a Hayes HFX9 or Mag you are probably S.O.L.
Gabriel Zink is offline
RS VR6 (04-13-2008)
Old 04-13-2008, 03:58 PM   #10 (permalink)
Bike Industry Slave
biglimey's Avatar
but then re-reading the original post a new Hayes way is the only way to go, or stick with V-s
I obviously havn't drank enough beer today!
biglimey is offline
RS VR6 (04-13-2008)
Old 04-13-2008, 07:27 PM   #11 (permalink)
Macross Frontier
RS VR6's Avatar
Thanks for the info.
I think I'm just going to stick with the V's in the rear and BB7's in the front. Mullet style.
RS VR6 is offline
Old 11-07-2008, 06:46 AM   #12 (permalink)
Do you happen to still have any of that hardware available for the Hayes 22mm brake set up? I have a 2000 Schwinn Moab Hard Tail that I am converting to disc. Thanks.
SchwinnHT is offline
Hayes Disc Brake 5" Rotor BobBurnes The Workshop 6 02-25-2008 04:55 PM
Hayes El Camino Disk Brakes 6" Front & Rear 6packguywith5spot The Market Place 12 02-13-2008 09:24 AM
Garage Sale - Fox Forks / Crank Bros Eggs Ti / Shoes / Moab Frame / XTR Pods and Rear boboso The Market Place 12 01-04-2008 10:27 PM
Hayes El Camino brakes Shu The Workshop 17 10-19-2007 11:05 PM
Hayes 9 bleed port plug fitment and questions Flat Broke The Workshop 0 08-01-2007 10:30 PM
