Old 04-07-2008, 12:39 PM   #1 (permalink)
Default U-Turn Sag Question
I'm picking up a U-Turn fork second hand, and I was wondering: how do I set sag on that?
The frame I'm putting it on is supposed to have 100mm. So, do I dial it down until it hits about 80mm with me on it?
My Blog
Old 04-07-2008, 12:49 PM   #2 (permalink)
Assuming you have the fork set to 100 mm of travel, adjust the air pressure until it has about 20 mm sag (the fork may show 80 mm on the leg). The amount of sag may vary, depending on the intended use.
el_d00der1n0 (04-07-2008)
Old 04-07-2008, 12:51 PM   #3 (permalink)
adjust the sag with the fork fully extended if it has more than 100mm travel. Then dial down to 100mm.
Trailwork on Silverado MW genusmtbkr5 Trail Conditions 17 04-22-2008 08:14 AM
Vote tommorow Rockinthecasbah The Pub 29 02-05-2008 08:33 PM
For those that aren't aware... Innes General Discussion 0 11-28-2006 10:55 AM
Sullivan Canyon Question mdbradigan Trailhead 9 11-11-2006 11:22 PM
Tour Dela El Taaacooooe Nnnnaaaazzzoooooe dirttorpeedo Trailhead 54 08-17-2006 12:58 PM
