Old 04-05-2008, 01:36 PM   #1 (permalink)
break yo'self foo
UseItOrLooseIt's Avatar
Default A thread on chains
I have had the same chain on my bike for about 20 to 30 downhill rides. My roommate says this can damage the bike pretty badly. at this point is it only the chain i need to replace, or a whole lot more?
UseItOrLooseIt is offline
Old 04-05-2008, 01:40 PM   #2 (permalink)
northshore's Avatar
I've had my chain for much longer. As long as you clean the chain and lube it accordingly the chain can last for awhile. Also if you are experiencing mis-shifting it could be your chain has stretched over time.
Hawaiian Island Creations
Ride it: dw-link.com/reasons
northshore is offline
UseItOrLooseIt (04-05-2008)
Old 04-05-2008, 01:41 PM   #3 (permalink)
break yo'self foo
yeah, there's definitely mis-shifting. a new chain oughta fix it?
Old 04-05-2008, 01:49 PM   #4 (permalink)
Bike Industry Slave
biglimey's Avatar
good way yo check if a chain is worn, is to use a steel ruler and look at the pin thats at the 12" mark. 12 1/16 OK 12 1/8 or more time to say bye bye buy...
But if it's mis-shifting you may have run it too long and might have to swap the cassette. Once a chain is at the 12 1/8th point it will start accelerating the wear on the cassette and front sprocket. Be carefull putting too much load on the pedals when you first put on a new chain, as if it is worn the chain will skip (and you may find yourself painfully straddling the top tube)
biglimey is offline
Blue Rat (04-05-2008), BrewMaster (04-05-2008), UseItOrLooseIt (04-05-2008)
Old 04-05-2008, 04:22 PM   #5 (permalink)
mytrustysteed's Avatar
Default slight thread hijack...sorry
does anyone see a big difference between shimano Ultegra and Dura-Ace chains?
WWJH....Who Would Jesus Hate?
mytrustysteed is offline
Old 04-06-2008, 07:09 PM   #6 (permalink)
cookie monsta
SnookDawg's Avatar
Weight is about the only difference as far as I can tell
SnookDawg is offline
Old 04-06-2008, 08:28 PM   #7 (permalink)
have you thought about sram chains? personally, i like how it is easy to link together... tool-less is nice...
faded1004 is offline
Old 04-06-2008, 08:47 PM   #8 (permalink)
Isn't there an issue with using Sram chains with Shimano parts?
My chain is ok right now so I'm a little nervous to change it right before Sea Otter
Old 04-06-2008, 08:54 PM   #9 (permalink)
Warrior Society Member
mtnbikej's Avatar
I have no problems running a SRAM PC-991 on my XT cassette.
mtnbikej is online now
Old 04-06-2008, 09:05 PM   #10 (permalink)
RacinJason's Avatar
Default My chain gang.
The sram power link works well on the Shimano chains.
You can run a sram chain on the all shimano drive train with no problems.
I miss match all the time in order to get the litest set up and never have any shifting issues.
I like XTR gog sets and I like sram chains and X9-X0 der's & shifters.
You can buy a chain stretch gauge or you can measure the links with a ruler.
At 12 inches your chain should be at centerpin to pin or at least real close.
if it is past that it is stretched.
I like the 991 sram chains a lot I use them on everything. The hollow pin is nice also if you want light.
KMC is stepping it up and pitting out some lite chains. I am still a little bit skeptical though.
I keep my chains clean and they last. The single pivot bike tend to blow trough chains a little faster than others. My DH bike hardly get chain stretch either because I am too weak or I just don't do enough climbing on them.
On the XC bikes I check for chain stretch every 3 ride but clean and re oil them every ride. When they stretch it seems to go all at once from my experiences.
Every time I have had a chain break it has caused a crash or a pedal strike to the back of the leg and a pulled muscle.
I hope that helps somebody
My sponsor house
RacinJason is offline
Old 04-06-2008, 09:35 PM   #11 (permalink)
I didn't know chains needed to be replaced so often. I've been riding on the same chain for 2 years, and it seems fine, no skipping or anything. Is that normal?
adrianko43 is online now
Old 04-06-2008, 10:05 PM   #12 (permalink)
Pickettt's Avatar
A worn chain will start to damage your chainrings and cogs. Both of those items are far more expensive than a chain. Get a chain checker for three or four dollars. Campy chains require a caliper, however. Next topic: failure. I rode a chain for six thousand miles once, it decided to break on me during a road sprint. It took an entire year for the torn ligaments in my ankle to heal. Trust me, it's worth a few bucks ($30-$50) to tend to your chain.
Pickettt is offline
Foesnasty (04-06-2008), wgb (04-09-2008)
Old 04-06-2008, 10:07 PM   #13 (permalink)
i think it has to do with all the climbing... as an engineering student, i can understand most of the stress would be from uphill power climbs.
i think downhill is alot of strss on the derailleur?
btw, i have lx crank + lx cassette + sram chain and it has been great. i don't ride too much, but then again i am just a beginner... everything is working great for me...
glad you recovered... since i have a full suspension bike, i hope to minimize my injuries from broken chain by trying to stay in my seat on power pushes...
Old 04-06-2008, 10:17 PM   #14 (permalink)
OUCH.
I was on a short but steep climb and my chain not being properly lubed and maintained decided to rerail it self on me as I was out of saddle power down just then it redrailed and THANK GOD i was leaning to one side when it did or else I would have had no need to get snipped because the top tube would have taken care of that for me
www.coverageispersonal.com
foofighter is offline
Old 04-07-2008, 07:07 AM   #15 (permalink)
back of the pack's Avatar
I thought I liked sram's amd the power link too, that was until it fell off riding Fully yesterday. It was a quick tool-less fix since I had a spare in the saddle pack, believe it or not I was able to get out of the Path for under $5.00 (had to pick up a new spare).
back of the pack is offline
Old 04-07-2008, 08:15 AM   #16 (permalink)
Derailleurs R4 Failuers
hoovermd's Avatar
As a SSer, I'm not in touch with any shifting issues, but a good strong chain is definitely my friend.
I'm not too picky about the brand, just that I run 9 speed chain and I always carry both an extra 4 inches of chain and some quick connect links.
I'm partial to the Wipperman links. Seem to be really reliable and easy to service w/o tools.
Mark
hoovermd is offline
Old 04-07-2008, 08:44 AM   #17 (permalink)
I've also had a couple instances where the Powerlink came apart. Unfortunately, they happened in fast downhill areas, and I didn't realize my chain had exited until I got the the bottom and had to pedal again. Both times, I had to hike up and get my chain. As a result, I've learned that Powerlinks are no good for geared bikes riding in rough conditions. They do work great for my singlespeed and road bikes.
There's a lot to be said for replacing chains often. On my DH bikes, I've had chains last a reasonably long time. However, that hasn't always been the case. Last year, when I did a trip to Whistler and Northstar, after NS, my chain was toast. It wasn't stretched, but a lot of links that were boarderline about to come apart.
Geek Thread... nappyt The Pub 357 09-02-2008 07:55 AM
IRS Rebate Thread Offshoot Roadstar_Rider The Pub 50 01-27-2008 07:53 PM
What happened to the Jenson thread? 2wheel_lee General Discussion 5 05-06-2007 07:46 PM
