Old 04-05-2008, 08:14 AM   #1 (permalink)
Default Rear shock sizing
I was wondering how one would determine the proper shock sizing for replacement/upgrade. I've seen some specs like "6.5 X 1.5" and references to stroke but it ain't jivin'. Is that the overall length of the shock X the travel of the piston?
Seat Sniffer is offline
Old 04-05-2008, 08:40 AM   #2 (permalink)
TCB
TCB's Avatar
Yes, 6.5 is the Eye-to-Eye and 1.5 is the Stroke or as you put it travel of the piston.
What bike are you replacing the shock
"Keep it singletrack” stay on the trail to avoid widening the trail, on narrow singletrack stop and lean the bike to one side to allow others to pass.
TCB is offline
Seat Sniffer (04-21-2008)
Old 04-05-2008, 10:10 AM   #3 (permalink)
on a routine expedition
Marshall Willanholly's Avatar
http://www.sicklines.com/tech/shock_details
Alex (04-05-2008), BFloFoxRider. (04-05-2008), Seat Sniffer (04-21-2008), station (04-21-2008)
Old 04-21-2008, 12:21 PM   #4 (permalink)
Thanks for the help guys. I had a heck of a time finding reference material. My mkiii has a low end manitou radium shock that's been getting a bit sticky lately, I'm still researching wether or not it can be rebuilt/upgraded effectively (Push?) or if I'm better off just getting a new one. I'm looking at a fox float R which is in my price range.
Old 04-21-2008, 12:56 PM   #5 (permalink)
i think if you buy it from somewhere like jenson they ask you what bike it's for.
edit: i know i was looking at rp23 a while back and some site i was on said they needed that info.
edit edit: it was blue sky: http://www.blueskycycling.com/produc...Rear-Shock.htm
**NOTE: We will need to know the year, make, and model of your frame when ordering a rear shock. This information can be provided in the comment box on step 3 of the check out process. Please note that due to the many makes and models, all rear shocks will have to be special ordered and can take anywhere from 4-7 business days.
My Blog
Old 04-21-2008, 01:27 PM   #6 (permalink)
mfoga's Avatar
If its an 06 or 07 it would be 7.5 x 2 I am not sure about any other years though.
mfoga is offline
Old 04-21-2008, 01:37 PM   #7 (permalink)
I'd rather be climbing...
KonaDupee's Avatar
I'd recommend simply removing the shock & taking it to your local bike shop. The manual for my '06 Kona was flat-out wrong. The folks at the Path thought I was crazy when I walked in and asked for a 6.5" x 1.5" (as stated in the manual--both online & in the manual that the Path had on their shelf). We broke out the tape measure and saw that it was 7.875" x 2". I'm glad they decided to measure it on their own.
It was a bit disheartening not to be able to trust the manual.
Climbing *is* its own reward!
It's obvious I'm not a weight-weenie; I ride a Kona!
KonaDupee is offline
Old 04-21-2008, 08:25 PM   #8 (permalink)
I had a good experience with the Cane Creek Cloud 9. It was pretty plush on my DW-Link. I would get an old school Fox Float with no ProPedal and get it pushed.
92se-r is offline
Seat Sniffer (04-22-2008)
Old 04-22-2008, 09:45 PM   #9 (permalink)
KonaDupee's Avatar
The Cloud 9 is what I upgraded to. I've been loving it so far. Cane Creek has the insane $100 rebate for sending in your old shock. Add the Path's 10% STR discount...I couldn't resist. $260 out the door, including shipping. It would have been close to $400 had I gone elsewhere.
It's taken me 5 or 6 rides to get the Cloud 9 dialed in, but it's really been plush so far. For my style of XC riding, it is all I need.
Old 04-22-2008, 10:00 PM   #10 (permalink)
http://aebike.com/page.cfm?action=li...Id=8129&type=T
I bought mine from here. Keep your old shock as a spare and just buy it normal priced here without worrying about sending in your old shock and getting 100 bucks back.
92se-r is offline
KonaDupee (04-22-2008), Seat Sniffer (04-22-2008)
Old 04-22-2008, 10:18 PM   #11 (permalink)
KonaDupee's Avatar
Wow, great deal. For that price, you should definitely keep your old shock as a spare. It'd be almost criminal to take $100 off of that price.
Plus, you have to go through a Cane Creek authorized retailer for the discount. May be worth the $100 simply to avoid the hassle of being sans shock for almost 2 weeks.
Old 04-23-2008, 04:01 AM   #12 (permalink)
If you need 7.5 x 2 here's a good deal
Fox DHX-Air 7.5 x 2
tkblazer: you pedaled up mathis? nice, i'm scared to ride down it
Seat Sniffer (04-26-2008)
Old 05-02-2008, 06:31 AM   #13 (permalink)
BFloFoxRider.'s Avatar
ok, question, i have a bike that takes a 7.5x2 shock.. if i put a slightly longer shock, 7.875x2, it would still work, it would just allow less travel correct?
Or am i totally off.. i tried looking around for info and couldnt find anything
Brandon FLOres
BFloFoxRider. is offline
Old 05-02-2008, 06:50 AM   #14 (permalink)
it would raise the back end if you had room, same amount of travel if your frame has clearance
first number is your length
the second is your travel (stroke)
BFloFoxRider. (05-02-2008)
Old 05-02-2008, 06:51 AM   #15 (permalink)
i know its got clearance... the shock runs vertically..
Thanks
Brandon FLOres
Old 05-02-2008, 06:56 AM   #16 (permalink)
check the clearance on the linkage and back triangle
Old 05-02-2008, 07:11 AM   #17 (permalink)
mfoga's Avatar
I know that with some bikes it will fit but it won't positively effect the bike but even negatively effect the bike.
I know there was a question about that for an IH MKIII on another forum and Dave W. (not sure how to spell his last name, the guy who created DW link) said that it would negatively effect the performance, that the link was designed specifically for that length shock. So it might not be to your advantage to put in a longer shock.
mfoga is offline
Old 05-02-2008, 07:12 AM   #18 (permalink)
b dog... to help you visualize
undo your shock... and raise the linkage another 1/8" inch, to simulate the longer shock. See if it has the clearance
Big Boys ride.....BIG wheels.
Chewyeti is offline
Old 05-02-2008, 07:30 AM   #19 (permalink)
your going to be rasing the BB height and on that bike I dotn think you want it any higher
WTB: rear shock Shu The Market Place 7 04-02-2008 08:36 PM
Anyone else have problems with Specialed rear shock? Scott V The Workshop 13 02-07-2008 05:48 PM
SOLD!!! YETI ASX lg w/ Rocco rear shock upgrade J_Sims The Market Place 19 01-03-2008 04:11 PM
is my rear Fox Float shock leaking??? .8down The Workshop 13 09-25-2007 05:18 PM
Fox Rear Air Shock BUSHING? PHAT TIRE The Workshop 4 03-12-2007 04:57 AM
