Old 03-29-2008, 01:17 PM   #1 (permalink)
ah buh bye now
Default PSA: Panaracer 29" Rampages and Stan's
Here's the equation:
29" Rampage + Stan's No Tubes + American Classics =
NIGHTMARE.
I'd explain more, but I have to go kill myself. Thank you.
Gone for good. PEACE.
Evil Chocula is offline
Burner (03-29-2008), DeeZee (03-30-2008), Pato (03-29-2008), SAR_boats (03-29-2008), sdyeti (04-01-2008), thephat (03-29-2008)
Old 03-29-2008, 01:26 PM   #2 (permalink)
Stanz conversions always have the potential for adventure. Some rim and tire combos are worse than others. There is always somone who has "never had a problem"(with such and such combo). Then there is always somone who did have a problem. Just because you have never had a problem does not mean that you never will.
I like stanz, but I have been yelled at more than once by angry customers after I sold them Stanz.
thephat is offline
Evil Chocula (03-29-2008)
Old 03-29-2008, 03:33 PM   #3 (permalink)
Big Guy's Avatar
I am trying it on my new wheels (being built now) but they are Stan wheels. I hope I will be in the "never had problem" group. I will keep you posted.
Gravity is on my side
Big Guy is offline
Old 03-29-2008, 03:38 PM   #4 (permalink)
ah buh bye now
Thanks.. the bead just will not sit in the rim.
Old 03-29-2008, 06:29 PM   #5 (permalink)
Results are much better if you use his rims, and not just a conversion kit.
thephat is offline
Big Guy (03-30-2008), J_Sims (03-29-2008)
Old 03-29-2008, 07:21 PM   #6 (permalink)
P. W. R.
J_Sims's Avatar
Truer words have never been spoken..
My successes
Arch's/Rampages on the RIP9 Never had a problem
355's/Specialized Resolution/Captain DOS never had a problem
Arches/Specialized Resolution/Captain SS Never Had a prob
My Failure
Salsa Delgado X's Listed on No Tubes dot com as recomended/Specialized Reso/Captain/Stan's Kit BOOM in the back of the car Stantastic fo sho
Big Thanks to :::
J_Sims is offline
Burner (03-29-2008), sdyeti (04-01-2008), thephat (03-30-2008)
Old 03-30-2008, 07:23 AM   #7 (permalink)
My successes
My Failure
and you didn't even yell at me after...
Have you tried leaving it aired up with a tube overnight first?
How about soapy watter on the bead?
You can put some weather stripping under the rim strip. This creates a tighter fit, and helps with inflation.
thephat is offline
Old 03-30-2008, 10:59 AM   #8 (permalink)
P. W. R.
J_Sims's Avatar
How could I, you were busy lacing up my new Arch's to some Hopes while I waited
Big Thanks to :::
J_Sims is offline
Old 03-30-2008, 11:06 AM   #9 (permalink)
ah buh bye now
did not try leaving a tube in overnight... I'll try that tonight. I did use soapy water though... is that supposed to help it seal?
Old 03-30-2008, 11:18 AM   #10 (permalink)
Good Grasshopper
JOx2's Avatar
smart move after all.
supposed to help the bead sit on the rim, pump it out you should hear the beads setting.
JOx2 is offline
Old 03-30-2008, 12:08 PM   #11 (permalink)
Big Guy's Avatar
I am getting the Flow with Hopes.
Big Guy is offline
Old 03-30-2008, 12:22 PM   #12 (permalink)
I made a Taco this big!
Choc are you using a compressor to air up or a floor pump? Unless your tire is a super tight fit on the rim e.g. Bonty DryX tires on Stan's. You probably can't get it to seat and air up with a floor pump.
Also make sure the valve stem you are using is tight so the there's no leak there either.
Pho'dUp is offline
Old 03-30-2008, 01:13 PM   #13 (permalink)
ah buh bye now
LOL.. floor pump. And, I was doing it in the shower (soapy water), so the I had to hold it off the ground!
So, far from ideal. The guy who sold me the bike is going to hook it up for me.
Old 03-30-2008, 06:07 PM   #14 (permalink)
Good Grasshopper
JOx2's Avatar
a spray bottle filled with soapy water is fine, no need to do it in the shower.
JOx2 is offline
Old 03-31-2008, 08:37 PM   #15 (permalink)
bikeaholic
bikeadict's Avatar
I've managed to seat a weirwolf LT in the arch with a floor pump and yellow tape
However, trying to mount my rampage to a Velocity Dyad has given me some problems. I ended up going with the 29er rim strip over top of a regular rim strip. I siliconed the valve in. I have to use a CO2 cartridge to get it to seat, but after that I can pump it up with a floor pump to keep pressure and work the stans magic to get it to seal.
I have to say though that the shot of gas to get it to seat is imperative. Either through an air compressor or whatever.
bikeadict is offline
