Old 03-26-2008, 10:59 AM   #1 (permalink)
andygua's Avatar
Default XTR Brake Adjustment
Hi there!
I've been trying to adjust my XTR disc brakes (07 model) but haven't been able to have them as I like...
My rear brake feels very "long" and I can't find the way to adjust the reach on the levers to make it shorter...
The pads are in good condition, so it's not that...
I used to have Juicy 7's and it was soooooo easy to adjust them...this XTR's are killing me!
Any ideas???
Thanks a lot!
andygua is offline
Old 03-26-2008, 05:01 PM   #2 (permalink)
ransom's Avatar
I tried in vain to find a link but to no avail. I found this in my Nov. 2007 Mountain Bike Action section ask RC.
Pull off the wheel and insert a clean piece of metal or plastic slightly thinner than your brake disc in between the disc pads, squeez the lever and reinstall your wheel. If you can't find a spacer try sqweezing the lever slightly. The object is to get the rubber seals that retract the pads to move a closer to the rotor. This moves the levers engagement point further outboard. If the brakes drag after your adjustments, simply remove the wheels and pry the pads a part with a clean flat flat head screw driver. Pump the levers with the wheels in place to reset the pads and try once more. The idea is to trick the XTR into engaging earlier, reducing the levers distance before pad contact.
http://www.mbaction.com/Me2/dirsect....FA668D&nm=FAQs
You may have to buy a back copy to get the entire article.
Hope this helps.
GL
ransom is offline
Alex (03-26-2008), andygua (03-31-2008), mtnbkrdavid (03-27-2008), schleppp (03-26-2008)
Old 03-27-2008, 07:24 AM   #3 (permalink)
Originally Posted by andygua View Post
Hi there!
Any ideas???
Thanks a lot!
By long do you mean that the pads engage with lever too close to the bar, or too far away? Or, is it an initial resting place of the lever issue? Anyway, have you tried messing with the reach adjusters (little allen head under the lever blade)?
thephat is offline
Old 03-29-2008, 03:19 PM   #4 (permalink)
nintense's Avatar
Default You have 2mm allen screw...
in the inner side of the lever.
If you mean the contact point is uneven, Shimano has an auto adjust system, if its not working, you need to bleed or service your brakes.
If you need any help, you can contact with me (I'm in Westwood).
Hi there!
Any ideas???
Thanks a lot!
nintense is offline
Old 03-31-2008, 10:56 AM   #5 (permalink)
good sugestion!!
skengines is offline
Old 03-31-2008, 04:44 PM   #6 (permalink)
andygua's Avatar
Yeah, by long I meant they engage to close to the bar...
Thanks man...you were right, the brakes needed to be bled. I took my bike to Helen's (never again btw, noob in town error) and they bled them and adjusted a couple of other things that needed attention.
I noticed now that there's a minimal rub between the pads and the rotor (although the engagement point is cool now). Should I reset the pistons to avoid that rub?
andygua is offline
Old 03-31-2008, 11:42 PM   #7 (permalink)
nintense's Avatar
Default If the rotor looks centered...
in the caliper slot, take off the wheel, press the pads all the way to the caliper with a clean big flat screwdriver, reinstall the wheel, put business cards both sides between the rotor and the pad, and squeeze the lever, go ride and have fun.
***don't do the process while the bike in upside down position***
Next time to have a better service experience in the west side, just check the link in my signature.
nintense is offline
andygua (04-01-2008)
Old 04-01-2008, 01:55 AM   #8 (permalink)
Bike Whisperer
DISCO's Avatar
The tolerances are rather touchy on these so I know exactly what you mean. If they are I.S. mount you will need to get some thin V-brake post sized washers to get them center with the slight variations from different hub/rotor manufacturers. If your fork is a standard QR and do not have a thru axle flexing and rubbing will always be a fact of life. All I can say is I am glad I tried these out before buying, I don't think they are worth the price and would E-bay them and get Hayes Strokers.
DISCO is offline
Old 04-01-2008, 11:40 AM   #9 (permalink)
nintense's Avatar
Default You would put the XTR on ebay to get...
Stroker ???
They are not even comparable.
I'm running on Shimano brakes for over 5 years (XT, XTR and Saint), I can insure you that even the Stroker won't stand even close to the top Shimano models regarding reliability, braking performance and simplicity.
nintense is offline
Old 04-01-2008, 05:21 PM   #10 (permalink)
andygua's Avatar
Thanks! I'll do that...just for my knowledge, does this achieve the same results as pushing the pistons back (reseting the brakes)?
Will do...I already wrote down the address to have it handy next time
andygua is offline
Old 04-01-2008, 06:35 PM   #11 (permalink)
nintense's Avatar
Pushing the pistons is the first step...
nintense is offline
Hayes Disc Brake 5" Rotor BobBurnes The Workshop 6 02-25-2008 04:55 PM
brake adjustment??? pinoiryder The Workshop 7 01-09-2008 10:26 PM
Hayes Brake Rotors & Pads project_d The Workshop 10 10-17-2007 09:40 PM
Check your brake cables UR2KLOS General Discussion 15 09-07-2007 12:28 AM
Brake lever pin missing Paul000 The Workshop 4 08-07-2007 12:09 PM
