Old 03-14-2008, 04:11 PM   #1 (permalink)
Client 9
Fired Yo Momma's Avatar
Default How often do you replace your cables
I am just curious
And the hangovers hurt more than they used to And corn bread and ice tea took the place of pills and 80 proof
And it seems like none of us do the things quite like we used to do
And nobody wants to get high on the town
And all my rowdy friends have settled down
-Hank Williams Jr.
Fired Yo Momma is offline
Old 03-14-2008, 05:15 PM   #2 (permalink)
Originally Posted by Fired Yo Momma View Post
I am just curious
It depends on a lot of factors including what cables and housing, what shifting system, what lube and how often, are there seals on the housing ends, what cable routing, do you use uninterupted housing, how much water exposure? There are other factors too. It can be as often as every month or so or a infrequently as every couple of years. Your tolerance for less than perfect shifting can be a big factor too.
I do it when I can feel the friction at the shifter, or when I can see the cable coroding or comming apart, or when the housing is visibly damaged.
thephat is offline
Fired Yo Momma (03-18-2008)
Old 03-14-2008, 05:18 PM   #3 (permalink)
DBD
I'm a cyclist
DBD's Avatar
When I need new shifters or the cable snaps.
DBD is offline
Fired Yo Momma (03-18-2008), Seat Sniffer (03-14-2008)
Old 03-14-2008, 05:26 PM   #4 (permalink)
i change mine at least once a year since i keep switching bikes out
Fired Yo Momma (03-18-2008), Pho'dUp (03-15-2008)
Old 03-14-2008, 06:35 PM   #5 (permalink)
Shrek must be destroyed
when shifting gets tough/rough.....
Its like 2 bucks a cable at jensons.... factor in half a six pack to do it and get the derailers dialed.
Usually... i will throw some new jaguar housing on it while im in there
-Aaron or Chewy
08 VOODOO Canzo 29er
08 Santa Cruz NOMAD
Chewyeti is online now
Fired Yo Momma (03-18-2008), wgb (04-02-2008), Zippy (03-14-2008)
Old 03-14-2008, 06:49 PM   #6 (permalink)
Small, but Mighty
Zippy's Avatar
Yup... You can keep them working longer if you move the housings around and wipe the cables clean after every ride (I'm anal) then lube them with chain lube or Lithium grease.
I usually have to replace them after the "wet" season because grit gets in there. Teflon coated cables help too.
L8 APEKS: "Never underestimate the power of stupid people in large groups."
Swim, bike, run.
www.zippyathlete.blogspot.com
Zippy is offline
Old 03-14-2008, 06:52 PM   #7 (permalink)
Crank it out
Alex's Avatar
Another question:
Originally Posted by thephat View Post
It depends on a lot of factors including what cables and housing, what shifting system, what lube and how often...
How much lube should you use in the cables? Is it just a dab at the metal ends, or should it go deeper?
vwolf - mtb'ers are the golden rule.
Alex is offline
Old 03-14-2008, 06:59 PM   #8 (permalink)
Small, but Mighty
Zippy's Avatar
Originally Posted by Alex View Post
Another question:
Shift your rear derailleur/ cassette into your biggest cog/easiest gear. Front could be middle or small. Without spinning your cranks, click the shifter until it won't click anymore. This will loosen your cable. Remove the housings from their bosses and slide them to expose the cable that they usually cover. Wipe the cables clean with a rag or cloth. Put a drop or two of chain lube or lithium grease on your finger and wipe the lube onto the cable. Replace the housing and taek up the slack in the cable by shifting the lever back to where it should be for what gear the bike is in.
Voila!
Not sure how to do it for brake cables. Someone else may.
Swim, bike, run.
Zippy is offline
Alex (03-14-2008), Fired Yo Momma (03-18-2008), reflux (03-31-2008)
Old 03-15-2008, 06:31 PM   #9 (permalink)
Tom Brady Look A Like
MTBMaven's Avatar
I read a few years ago on MTBR that Dura Ace cables have the least amount of stretch of any other cables. This was based on a study by some German MTB mag. You know the Germans. I only buy Dura Ace cable now.
You must be the change you wish to see in the world Mahatma Gandhi
Border? I have never seen one. But I have heard they exist in the minds of some people. Thor Heyerdahl
All steel stable: '08 DeSalvo - '07 Niner MCR9 - '89 Specialized Sirrus fixed/free
MTBMaven is offline
Old 03-17-2008, 10:41 PM   #10 (permalink)
brownlandshark's Avatar
I replace mine about twice a year. Housing compresses more than cables stretch. From time to time you need to dis connect the cable and snip the frayed out end of your shifter housing. I lube the cables often.
The jesus and Mary Chain is the greatest band ever
brownlandshark is offline
Old 03-31-2008, 02:57 PM   #11 (permalink)
Dizle's Avatar
So what housing and cable is everyone running? Dura Ace? Avaid Flack Jacket? others? I'm redoing mine with full length housing and want to get some good s**t
Dizle is offline
Old 03-31-2008, 03:12 PM   #12 (permalink)
i replace mine whenever they stop working i run whatever housings and cables they have at jensons that moment
Old 03-31-2008, 03:48 PM   #13 (permalink)
reflux's Avatar
To answer your question...not often enough.
That being said, my bike started its once-every-3 year overhaul yesterday. Funny timing with this thread: I am picking up new cables and housing tonight. It's an easy job, though it's just low on the priority list. Once I get my truck back, she's off to The Path for them to look at the creaking (Turner) and the pos crankset (RF deus).
reflux is offline
What do you call those things you use to keep your cables in the cable guides? TooManyTacos The Workshop 6 02-25-2008 09:30 PM
Looking for a Medium trailbike to replace the Giant Reign I just had STOLEN. Evil Chocula The Market Place 22 10-30-2007 07:39 PM
Check your brake cables UR2KLOS General Discussion 15 09-07-2007 12:28 AM
White Cables sandblast The Workshop 5 08-26-2007 11:15 AM
And now for my next stoopid question...CABLES...eek! L8 APEKS The Workshop 0 04-24-2006 10:56 AM
