+ Reply to Thread
Results 1 to 11 of 11
Thread: Fox rp23 why won't you lock out?
  1. #1
    Is this thing on? station's Avatar
    Joined
    Mar 2007
    Thanks
    2,308
    Thanks earned: 1,530
    Default Fox rp23 why won't you lock out?
    Hi, so I've had this shock for about a year now and it's cool but I can't seem to ever really "lock it out". No matter how much air, or how hard I turn that blue arm it's still squishy. I mean, yeah it's not as squishy but it's no hardtail* The LBS tells me people used to blow out shocks that locked out all the way and the squishy feel is normal.
    *You know the triad right? That thing locks out solid.
    Also, what's with this pro-pedal? I mean, no one (including Fox online-or the operator's manual) can really tell me what is stiffer 1,2,or 3. I mean they can tell you what is the "higher setting" but what is that? They all three feel about the same.
    Help before I trade this for a triad or some specialized rear shock.
  2. #2
    Wanna ride? Solo's Avatar
    Joined
    Dec 2007
    From
    Carlsbad
    Thanks
    890
    Thanks earned: 399
    Sort of a misconception, no rear shock will fully lock out and feel like a hardtail (trust me, I've tried). Even in lockout mode, both the RP23 and Triad have a little bit of travel.
    They both also have a blow off feature meaning that the shock will compress through its travel (intentionally) if you land a big hit in the lockout mode. This protects both the shock and your frame gussets from bending or breaking.
    A better idea idea to lock it out is to jam a big stick between the frame and rear triangle!
  3. post thanked by:
    station (03-13-2008)
  4. #3
    northshore's Avatar
    Joined
    Oct 2007
    From
    Foothill Ranch, CA
    Thanks
    5,018
    Thanks earned: 3,238
    Quote Originally Posted by station View Post
    Isn't the specialized rear shock simply a re-badged and possibly re-valved Fox? Also, *cough*DW-LINK*cough* works even with the pro-pedal turns off for climbing!
    Hawaiian Island Creations
    Make a difference: www.imba.com
  5. post thanked by:
  6. #4
    Get your own avatar idea
    Joined
    Nov 2004
    Thanks
    1,199
    Thanks earned: 1,912
    Do you have an RP3 or a newer RP23? The differences between settings on the older RP3 are not nearly as noticeable compared to the new RP23. If you put a newer RP23 in pro pedal on #3 it is pretty much locked out. If you've got the older style RP3 then send it to PUSH or get a newer RP23.
  7. post thanked by:
    station (03-13-2008), thephat (03-14-2008), un-kola (03-13-2008)
  8. #5
    STR Veteran jschwart73's Avatar
    Joined
    Nov 2007
    Thanks
    288
    Thanks earned: 643
    The Triad is junk, don't "upgrade" from a RP23 to a Triad.
    I swapped out the Septune on my Stumpy to a RP23 and it has been a great shock. To be honest, I started off using ProPedal3 when climbing and have slowly ratcheted it down to PP1. When climbing technical obstacles, it simply works like butter for me.
    Also, you mention adding air to control bobbing - Try to avoid that, it's not the purpose of the air in your shock. Use the air to set sag and then control dampening with the rebound knob and ProPedal setting. If you check the manuals on Fox's site, you'll find recommended sag settings depending on the length and stroke of your shock.
    Don't let the bob bother you, your bike actually might be working quite well for ya.
    Toy Cars and Mountain Bikes
    Coming Soon - MTBPics.net - A MTB Video and Photo Archive destination
  9. #6
    Live Free, Ride Hard Jman's Avatar
    Joined
    Nov 2007
    From
    Wildomar, CA
    Thanks
    1,843
    Thanks earned: 1,459
    I have a Triad on my FSR XC and when I locked it out on the steep pavement climb at Fontana it is LOCKED period. I know that it'll blow-of if I forget to reset it but there is a noticeable difference between the two three settings. Trying to pedal with the Pro-Pedal off is like being on a pogo stick...it's great for the DH section though. Good luck with it.
    '11 Specialized Tarmac SL2 Comp
    '11 Specialized Camber Elite 29er
    '07 Santa Cruz Heckler
  10. post thanked by:
  11. #7
    Joined
    Mar 2007
    Thanks
    2,308
    Quote Originally Posted by TURNERob View Post
    it's the rp23. What does push do exactly? Is it worth the cash?
    Quote Originally Posted by northshore View Post
    yeah dw-link. ha
  12. #8
    Joined
    Nov 2004
    Thanks
    1,199
    Push modifies the internals of the shock and custom tunes it to your weight, bike and riding style. They can add more platform and at the same time make it much more plush when not in pro pedal. If you have the RP23 in pro pedal mode on #3 and aren't satisfied with the amount of "lock out" then there could be something wrong with your shock. Give Push a call, www.pushindustries.com
  13. post thanked by:
    station (03-13-2008), un-kola (03-13-2008)
  14. #9
    Joined
    Mar 2007
    Thanks
    2,308
    maybe I should trade for a brain fade and have some posts welded on to handle the brain part?
  15. #10
    A little Shaggy Bryguy17's Avatar
    Joined
    Dec 2007
    From
    Fullerton, CA
    Thanks
    7,227
    Thanks earned: 6,890
    okay, here's what I've dealt with regarding the RP23:
    On my trek, it works amazingly. the setting is stiffer the higher the number. 1 being the lightest, 3 being the stiffest. In my experience, there is a noticeable difference between the three, as well as a very noticeable difference between open and propedal modes (open with lever away from air valve, propedal with lever to the same side as the air valve).
    If you aren't noticing a difference between the two, try setting it up for the proper sag in open mode. Then go ride around and play with the settings. In Pro-pedal 3, i can be out of the saddle mashing and the suspension will only move in response to bumps and not pedaling. If that doesn't work, you might have a defective shock and might conside having fox take a look at it.
  16. post thanked by:
  17. #11
    Stop stealing my thunder! Pato's Avatar
    Joined
    Sep 2007
    From
    Downey, CA
    Thanks
    4,527
    Thanks earned: 2,196
    The RP23 does NOT have a lockout. The blue lever is to turn the ProPedal (platform) on and off. The knob with the numbers is to set the amount of ProPedal. I think you need a new lbs if they couldn't tell you that much.
  18.    Sponsored Links
+ Reply to Thread
  1. 6.5" x 1.5" Shock - Fox RP2 or RP23
    By dubjay in forum The Market Place
    Last Post: 01-28-2008, 06:06 PM
  2. Trade or Sale: Fox DHX Air for RP23 or cash.
    By Rivet in forum The Market Place
    Last Post: 01-18-2008, 08:34 PM
  3. 2007 Fox DHX-A for RP23 7.875 x 2
    Last Post: 11-16-2007, 10:09 AM
  4. RP23 vs. DHX Air
    By PacMan in forum General Discussion
    Last Post: 09-06-2007, 01:15 PM
  5. Stripped Lock ons
    By imapodaddy in forum The Workshop
    Last Post: 06-23-2005, 04:13 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
