Old 03-06-2008, 02:55 PM   #1 (permalink)
Or Not Enough
TooManyTacos's Avatar
Default Installing cassette on a 10mm bolt on hub
Okay, so I bought a replacement rear wheel that has a 10mm bolt on rear axle instead of the QR. How do I tighten the lockring on this thing? My lockring tool has this long pin that goes into the QR thing.
TooManyTacos is offline
Old 03-06-2008, 02:57 PM   #2 (permalink)
Default Take the bolt out?
Old 03-06-2008, 02:58 PM   #3 (permalink)
Or Not Enough
Haha, okay, good plan. Any instruction on how?
Old 03-06-2008, 03:03 PM   #4 (permalink)
DBD
Old man goin' downhill
DBD's Avatar
I have never had that problem (not quite sure what the problem is), what tool are you using? got a pic or two?
I use the same tool for a qr, 10mm and 12mm axles, and there is no pin in the center
DBD is offline
Old 03-06-2008, 03:07 PM   #5 (permalink)
Question Type
Is this a through bolt or threaded axle? We need pics
The bolt that holds the wheel to the frame needs to come out. It should just back right out
Old 03-06-2008, 03:12 PM   #6 (permalink)
Either remove the axle or get a tool that has an opening for an axle to go through it.
Old 03-06-2008, 03:16 PM   #7 (permalink)
Or Not Enough
Hmm, I guess it's a threaded axle. It has two 15mm nuts on each end.
My lockring tool looks pretty much like this:
I'm not exactly sure how to remove the bolt. I think I can see how--but it looks like I'll need TWO 15mm cone wrenches.
Old 03-06-2008, 03:18 PM   #8 (permalink)
Default Ok
Take the nuts off.
Old 03-06-2008, 03:18 PM   #9 (permalink)
DBD
DBD's Avatar
Like the BMX bolt on axles, ahhhh, and some DH. You neeed to rip that pin out OR better yet, go get the correct tool without the pin.
DBD is offline
DeeZee (03-06-2008)
Old 03-06-2008, 03:23 PM   #10 (permalink)
Park FR-5:
DeeZee (03-06-2008), singleSSpeedster (03-06-2008)
Old 03-06-2008, 03:28 PM   #11 (permalink)
Or Not Enough
Ah shoot, so I gotta buy more stuff!
Old 03-06-2008, 03:30 PM   #12 (permalink)
DBD
DBD's Avatar
Personally I would just stick the tool ya have in a vice and drill the pin out or use a drill press.
DBD is offline
Old 03-06-2008, 03:31 PM   #13 (permalink)
Pato's Avatar
TMT,
I live in Downey and work in Monterey Park. You can borrow mine.
Duc
Pato is online now
Old 03-06-2008, 03:34 PM   #14 (permalink)
Or Not Enough
Thanks everybody for your help. I'm heading over to the mall and can probably pick up one of these FR-5s that you speak of at Sport Chalet.
Maybe I should've just bought a QR rear wheel!
Old 03-06-2008, 04:45 PM   #15 (permalink)
If it's not too late, I had one of those type and needed tu use it to remove a Marzocchi top cap if I recall. When I bought the tool, the salesperson told me the pin on the one I had was meant to shear if you wanted to remove it. I just put the pin in the vice and whacked the tool with a hammer and the pin sheared at the base. I don't have my tool in front of me so I can't tell you which brand it was. but that might save you some $$.
Chris
Flat Broke is offline
Old 03-06-2008, 05:35 PM   #16 (permalink)
Rolling on 29" dubs!
Park FR-5:
bingo. had to buy one yesterday for my ss monstercross ( i have a rear dura ace hub converted to a 10mm solid axle with track nuts). only $8.
this is what the o.p. will need.
"forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
singleSSpeedster is offline
2wheel_lee (03-06-2008)
Old 03-07-2008, 03:06 PM   #17 (permalink)
I Ride Bikes
RED5's Avatar
Drill out your lockring tool!! That's what I did, works great.
RED5
RED5 is offline
cassette and chain help!! lukewiens The Workshop 17 08-09-2008 10:00 AM
Road Cassette Bert General Discussion 11 01-23-2008 05:52 PM
Removing a broken bolt BrewMaster The Workshop 22 01-04-2008 09:48 AM
installing cables/housings. .8down The Workshop 56 12-20-2007 10:40 PM
- shimano M760 XT 11-32 cassette tkblazer The Market Place 0 09-05-2006 12:35 PM
