#4 (permalink) | |
Well, I was going to use Thomson's specs which is 35 in/lbs for the stem to bar but not sure about the lock-on grips and gripshifters. What techniques do you suggest? |
My elbow goes click click. Actually, the noise comes from my mouth. That's my torque wrench for a lot of things. You wrench long enough on cars, you know what certain torque specs feel like. Something like handlebars and stems, I wouldn't worry too much about using a torque wrench. I'd just worry about overtightening.
BTW, I do have a torque wrench, but I only use it for important stuff, like installing cams, or assembling a bottom end. You know, stuff that goes 7500 rpms. ![]() |
bighit8 (03-05-2008)
Use a 3/8 speed wrench . Use the tightening hand as a pistol. Pretend you're hand is like pointing a gun on the wrench if that make sense.If you do not have a speed wrench, just use a 1/4 inch ratchet with the same technique, just hold back a little.Use only the index finger for pressure.Make sure you snug them up first and then use a cross pattern. Top left to bottom right, bottom left to top right.Hop this helps. Also 35 inch pounds is just under 3 foot pounds, so just go easy.
Roger: You guys should join us next Sunday. It would be nice to have another screamer CHEWYETI: Heat, Beat, Repeat! ![]()
#10 (permalink) | |
How about this: I was thinking that I'd snug everything up and then go with 1/8th turn increments until I'm pretty sure it won't move under riding conditions. I'm guessing probably no more than 1/4 turn passed snug will do it? |
basucally yeah hes saying use only your index for the final torque, there isnt a neighbor or bike shop what has a wrench available for you if your this worried? seriously though for bars just get them nice and snug hop off some curbs and double check they dont move and your good to go its not rocket science these new fangled bicyle thingys arent that tricky, just becareful not to kill them and youll be ok
#13 (permalink) | |
brett (03-05-2008)
Warrior Society Member
Ummmm......I don't think you are supposed to be using lockon grips on carbon bars? ![]() ![]() |
#15 (permalink) | |
Dunno. What would be the difference between lockons and gripshift on a carbon bar? I'm pretty sure a lot of people use gripshifts and carbon without incident. |
35in/lbs feels like absolutely NOTHING. That is like 3 ft/lbs. You can use your allen wrench and flip it around, using the short end to torque it down. Use your left hand to hold it inside the allen bolt, and use your forefinger and thumb to tighten. No way you will be able to overtighten this way.
#18 (permalink) | |
You do not tighten down your gripshift at the end of the bar like you do with lockon grips.......similar to why you don't run bar-ends on carbon bars. |
#20 (permalink) | |
Lebowski Urban Achiever
Umm...don't look too closely at my bike, OK?
Just because the bike can do it doesn't mean the rider can! "My ass is sore after a long ride." - MtnKitty " If you feel like you're going fast, you are!" -CalEpic |
