I have a set of Juicy 5's, and almost since new (about 3 years old now) the rear brake handle retracts slowly. I brought it into Switchback cycles and Tim did a complete system bleed and check, but no relief. He says we might need to send it in, but before I did that wanted to see what you guys might think it could be. Any other ideas as to why the brake lever is slow to recover after using the brake. It is almost as if it goes in slow motion, well not that slow, but slow enough to make it slightly annoying. Thanks for the insight.
3 yr old? What do the pistons look like? Do they have any surface rust? a little polish/seal swap/ rebuild could be in order.
DO check to make sure your lines are not kinked and your return spring is there
Chewy THE Yeti Call me Chewy or Aaron THE STABLE: GF rig, Voodoo canzo 29 Big Boys ride.....BIG wheels. |
Thanks for the ideas anyways. |
the springs on juicys are external mounted to the pads you should be able to see them
| Avid Juicy 7 issue... brand new | Chewyeti | The Workshop | 12 | 10-26-2007 07:44 AM |
| Avid Juicy 7 - Problem | cjwally | General Discussion | 20 | 10-25-2007 04:16 PM |
| 07 Avid Juicy 5 brakes, 203mm rotors | Marshall Willanholly | The Market Place | 15 | 10-18-2007 01:32 PM |
| Avid Juicy 7 w/ upgrades | SSinGA | The Market Place | 3 | 09-07-2007 02:37 PM |
| Juicy 5 Question | Rossage | The Workshop | 4 | 05-21-2007 07:42 PM |
