Shrek must be destroyed
Hi all,
I have this fork, and want to up the travel to 100 i believe. I have the 'included magic spacers' to do this, but no instructions or any idea on HOW to do it. Anyone done it? Is it easy? What tools are required etc.... Thanks!
#2 (permalink) | |
![]() ps. The procedure is the same for the 26" and 29" versions. Good luck! |
Chewyeti (03-03-2008)
I read that the Reba Race can be converted, but not the Reba SL.
I think I copied this from Rainman's site: Reba Travel Adjustment. Here's the quick and dirty on the Reba travel adjustment setup. Let the air out of the positive and negative chambers. Remove both valve cores. Compress the fork and attach a strap to hold fork compressed. Unscrew the 10mm nut on the bottom of the left leg until it is flush with the end of the negative air chamber threads. Tap the nut with a soft hammer to unseat the air chamber (or air piston rod) from the slider. Some oil will drain out so have a catch pan ready. Remove the 24mm top cap from the left leg. Use a thin rod to carefully push the air piston out of the top of the left leg. Carefully push the thin rod through the hole in the bottom of the slider against the air piston rod until the air piston comes out the top of the leg. Under the air piston is the spacer if the fork is set up for 80mm, or no spacer =100mm. If going from 80 to 100 remove the spacer, if 100 to 80 add the spacer. Carefully push the air piston down past the threads inside the stanchion about an inch. Add 3-5cc 5wt Rockshox oil on top of air piston. Install the positive air cap (24mm) and torque to 60 in/lb. Install the positive chamber valve core. Turn the fork upside down and with a syringe add 15cc of a 50/50 mix of 5wt and Red Rum through the hole in the slider. Using a shock pump on the positive chamber add enough air to force the threaded portion of the piston rod out the bottom of the slider. Install the 10mm nut and torque to 45 in/lb. Remove the holding strap, inflate the positive chamber to the desired pressure, inflate the neg chamber 10 psi less. Install both air cap covers, clean the fork and you are just about done. E Z.
![]() Maybe we are talking about two different things. I had a Reba on one bike set at 80mm and another at 100mm. The travel setting did not effect "fork flex". Meaning the both felt the same except the 100 felt more plush. ![]() Wasn't comparing 20mm to Standard .But a Fox Standard Fork is the Chuck Norris of forks. Just ask Fo Shizz ![]() ![]() |
BrewMaster (03-03-2008)
never mind............ ![]() |
its funny because yesterday on a ride my buddy asked if my front wheel ever felt noodly on turns and i said no... he is running a reba up front
DeeZee (03-03-2008)
![]() I saw a guy this weekend on the Fox 29'er fork. I asked him "I didn't know you could get those in Gray I thought they were all White". He said "they only come in White......my seals are leaking" ![]() |
Chewyeti (03-03-2008),
foofighter (03-03-2008)
he says 5wt rock shox oil AND red rum?
wtf is red rum? not alcohol right?!?!?!? and not ATF (Automatic tranny fluid...)
Bike Whisperer
Flimsy forks are in the eye of the beholder, it is aggravated by the inherent lack of stiffness in a standard QR skewer. If you are over 180 Lbs and or like to relive your BMX glory days. Currently I ride a 10mm thru axle in the front but will be swapping pike lowers onto my fork to prevent rotor rub when heeled over.
| Reba 29er w/ poploc | Chewyeti | The Market Place | 5 | 02-25-2008 04:57 PM |
| RockShox Reba 29 100mm $150 | Padre | The Market Place | 13 | 01-29-2008 07:32 AM |
| I need a Reba 29er fork | Uncle Rico | The Market Place | 3 | 01-25-2008 01:00 PM |
| Reba Race 29er, Pace RC31 29er, Moots stem | Uncle Rico | The Market Place | 9 | 01-20-2008 08:16 PM |
| Good deal on Reba 29er SL | tbowren | The Market Place | 13 | 08-22-2007 05:24 PM |
