ali'i hua
so, anyone that rode near me on the SS love fest on Sunday heard quite possibly the most loud and annoying SS on the planet.
of this, I apologize. so, it's a Race Face Atlas crank/bb setup with their fancy x-type external BB cups on a titanium frame. the cups and cranks are tightened down properly, and all the spacers and washers are in the correct locations- this is per the destructions, Karl at the path, and a pic exchange with race face. could i need ti-prep or something like lock-tite? the splined interface between the axle and crank arm is also greased. other notes: the bike has been ridden exactly 2x since the 2007 counting coup, where it performed flawlessly for the whole race. it's got the stock thread lock "goop" on there as well. it doesnt feel like the creak is at the pedal/crank interface at all, and it happens while seated or standing, so it's not the seatpost...besides that's a ti post in a ti frame.... help!
"...the weather will continue to change, on and off, for a long, long time" -Al Sleet, the hippy dippy weatherman RIP George Carlin http://www.myspace.com/setswim |
#4 (permalink) | ||
ali'i hua
It only take about five minutes to pull it apart and put it back together, so I don't mind much. After years of bending square taper spindles, I'd rather re-grease than buy new BBs or spindles. Never fell for the Isis thing.
slowSSer (02-19-2008)
Restepct.
Are you sure it's not the EBB creaking? (If you're running an EBB, that is...)
26'er Zen Master (02-18-2008)
#9 (permalink) | ||
ali'i hua
the brakes are an entirely different situation- the king ISO disc mount is on crooked.
You stated the buike has not been used much last year. I would guess the bearings may have rusted, I would go out and by a set of Enduro Ceramic bearings and replace them.
ali'i hua
besides- what do a set of enduro's go for? and how rebuildable are the external cups? thanks ![]()
Try taking the chain off and pedaling standing up. If the sound continues pull both sides of the bb off and feel the bearings.
If they feel dry you will feel a grittiness. Clean everything and regrease what you can by pulling of the bearing dust covers. Sontimes I use an ultrasonic cleaner. But brake cleaner or degreaser works just don't get it on your bike frame or paint. I re grease everything with boat axle grease its green. You can find it at pep boys we have been using it on bikes since 88-89 It last longer than other greases and can handle being submerged in water. Then I put the bearing and cups back together. Grease the threads with the same grease. Thread them back in. Torque bb. Then grease the shaft on the cranks before reinstalling them. Torque everything down. Then checking to make sure nothing on your cranks are rubbing on the frame. Also check your chain rings to make sure they are not moving. Test it . It should be silent. After all of this. Good luck. Let me know how it goes. J |
slowSSer (02-20-2008)
| a couple questions | chauvinist_youth | The Workshop | 11 | 11-24-2007 06:56 AM |
| External BB for Truvativ Crank | mtnbikerdude87 | The Market Place | 8 | 09-14-2007 12:28 AM |
| Really Stuck BB, worst ever. | FyrFytrRyn | The Workshop | 10 | 03-30-2007 11:52 AM |
| How long is your BB? | Buzzsaw | The Workshop | 8 | 04-21-2006 10:33 AM |
