#141 (permalink) |
I dug the SB8 at first. Then I hated it when I could feel the side wall folding and rolling around. Just wait...
#143 (permalink) |
im living with my tiny 2.1 pythons , they roll fast and i can deal with a little spin
#144 (permalink) | |
Chewy THE Yeti Call me Chewy or Aaron VOODOO Gonzo 29 Big Boys ride.....BIG wheels. |
onlyontwo (06-03-2008)
#145 (permalink) | |
Secret Squirrel Society
"The Path is simply the best bike shop in Southern California." - Brewmaster ![]() www.thepathbikeshop.com ![]() |
#147 (permalink) | |
On fast turns or through rocky areas I could feel the side wall flexing. On a hard turns it felt like the tire wasn't following the line of the wheel. I went up to 40 psi to to stiffen the sidewall, but then the traction went to crap. This was with tubes. I am quite happy with my Crossmark 2.1 running tubeless at around 30 psi as a rear tire. I hope to do CC next year. I still like having a wider tire in the front. 2.3" is nice and I feel like I can load it more in turns without worrying about washing out.
#148 (permalink) | |
![]() I will change out tires for more agressive trails but for Cross Country IMHO..2.1 is all that is needed ![]() |
#149 (permalink) | |
A wider tire up front works for me, so I'll keep doing it.
#150 (permalink) | ||
if that is what you like ![]() Quote:
![]() My whole point is that with the bigger hoops you can get by with a skinnier tire ![]() |
#151 (permalink) | |
They are supposedly a pretty snug fit on the Stan's rims (according to Mike from Stan's). |
#152 (permalink) |
I ran the Cortez 26 x 2.2 before as a rear tire. It is essentially the same thing as the Karma as far as I can tell. It was a great tire. I'd consider running the Karma but I like my Crossmark too much to switch.
dubjay (06-03-2008)
#153 (permalink) | |
But, I'm running a 1.9 29er as a rear tire on my Dos and it is fast. I am loving it so far. I may try it as a front tire as well later this year. I'll never every speed/rolling advantage I can get next year ![]() |
dubjay (06-03-2008)
#154 (permalink) |
Duan'er - 29'er remixed
has anyone tried the Panaracer Rampage in the rear? Just curious because i was thinking bout trying that...the ignitor in the rear dont seem to work that good.
#155 (permalink) |
Im not a fan of the Igniters either, especially in the front- crappy front tire.
I have ran the Rampages in both directions on the back. In the rear direction, traction is great but it has quite a bit of rolling resistance. In the forward direction, it rolls better but you lose quite a bit of traction. IMO, I like the Rampage ran in the rear direction, it sticks and is predictable, but you will feel the difference pedaling it on the climbs. It sticks, but you will work harder. |
#156 (permalink) | ||
It is going to start getting dry and loose....put the Ignitor up front and get a fast roller for the rear ![]() Quote:
Talk to scutr about that...he runs that tire front and back on both of his bikes. It is one of the best front tires I have tried for all around conditions. |
#157 (permalink) |
i'm not sure if i like the ignitor in the rear...maybe i have too high psi? I'm running 30psi right now in the rear...running resolution in the front right now...maybe thinking of getting some captain in the back?
#158 (permalink) | |
Fair means I win
The Panaracer Rampage is basically the exact same tread pattern as the Kenda Nevegal. Same casing and roughly the same weight too. I think the only difference is rubber compound. |
foofighter (06-06-2008)
#159 (permalink) |
Fair means I win
I am running the WTB Weirwolf LT 2.55 on the front and either the Kenda Nevegal 2.2 or Kenda Karma 2.2
The Weirwolf is great for taking the bumps but if you run pressure too low it wants to roll, too high and you lose cornering traction. Right now I am running 28psi and it is ok. The Karma is fast rolling and hooks up well in hardpack and over rocks. it is a 120 tpi tire so it feels very nice and plush. It doesn't hook up as well as the Nevegal but then again there arent many tires that do. |
#160 (permalink) | |
Another tire that's worth a look, besides the 1100g weight, is the WTB Stout. GOBs of traction and quite honestly, they don't roll as bad as you'd expect them to. I'm actually running them both f/r, tubeless, right now. I can climb shit I never made it up before, descending they're like glue. Don't ride them on the street or really flat trails - They make road noise like one of those massive lifted overcompensation trucks you see rolling down the road... |
I'd need a 36T anyway
