Put MBenga in!
Stan's Arches. I was running about hi ~35psi tubeless on a Resolution 2.3 on the front. Stan's sealant too.
I know the saying goes "Measure twice and cut once", but I prefer my method of "casually estimate once, cut once, and regret forever". -teamdicky |
I've been running them ~27psi, I'm 170lbs
Trail Paparazzi
That is kind of bad to hear... Justin made me get one for a front tire for VQ. I'll be spending a lot of time on Main Divide also.
2007-08 NBA Champions
Allison you should wait to see that the trails will be like the day of the ride ![]()
Red Hot Sloth "where I grew up bling bling would get you shot, same with the lycra" Dirtmistress "Hey! I resemble that remark! I was born in Berkeley and have the chin hairs to prove it!!" |
Trail Paparazzi
As for Ignitors, I sliced one of those also, so Justin isn't gonna put that on there either. |
Put MBenga in!
I'm pretty terrible in gravel and probably grab too much brake which doesn't help things. I think a grippy tire up front works better for me.
SS'ing Nightmares
I know we all have our own opinions, but I for the first time, I have finally found a set of tires that I would be happy putting on time and time again. I have ridden this set of rubber on the Summer dust to wet Winter mud and have yet to not be amazed.
Put a Weirwolf LT 2.55 up front and a Rampage 2.35 in the rear and you are set. |
Trail Paparazzi
Wally - If I wasn't racing I'd probably be using a Rampage front and something else on the rear. I liked Rampages! |
For example dry hard pack I would prefer the Bonti XR's ps. All tires can be sliced ![]()
SS'ing Nightmares
![]() DZ....True, but some sidewalls seem to be thinner than others.... |
![]() ![]() ![]() If I an riding rocky stuff the Resolutions go on my rig. Smoother trails I use a different lighter tire. ![]()
Trail Paparazzi
mirroring the trail
Thanks for the heads up on this tire. It's perfect for a race I'm going to do later this year.
Pho'dUp (02-19-2008)
This thread is now a "sticky"
The "new Ignitors" are 690g and have thicker sidewalls. The older ones (that I have) are 600g. Scutr and I have been running these under are fat arses with out a problem.
ps. I still like the tried and true Nano ![]()
Beer! How did you know?
Yup --- dropped the pressure to 35 psi and it gripped a lot better. I still have the scrapes to prove that 40lbs is too much for that tire. It also felt a lot more cushy --- I have the tire on a hard-tail.
So here is my 2 cents about the Rampage/Crossmark combo...The Rampage might not roll as well or be as light as some but the extra grip is a must (for me) for the Coup. Besides the Rampage rolls really well. The Crossmark is a great roller and grips enough for a geared climb. I will be experimenting with running them both tubeless to get the pressure a little lower after the Coup. I tried the Rampage at 28psi once and it gripped better than some 2.5 down hill tires I have run. I worry about pinch flats, though, at that pressure so I am going to try tubeless. The Crossmark is likely to be my favorite fire road x-country race tire. It rolls well, is light, and grips enough to keep you over center -- as long as you are not trying to completely bomb down the trail. I am not sure, though, that it will hold up for my single speed. It tends to slip while out-of-the-saddle climbing at its lowest pressure. Maybe running it tubeless will make it hook up a little better and make it acceptable for my SS. If not I am going to try the Captain in the rear (oops). ![]() ![]() Quote:
"He was a wise man who invented beer." - Plato ![]() RES FIRMA NITESCERE NESCIT
allison (02-19-2008),
jschwart73 (02-19-2008),
Pho'dUp (02-19-2008),
tbowren (02-27-2008),
tkblazer (02-19-2008)
Treading Trodden Trails
With all the love for Ignitors in this thread, I may give them another try. I had them stock on my 26er and they wore out quickly and they sucked on out of the saddle climbs when I needed traction the most. What pressures do you all run Ignitors at? Tubed or tubeless conversions?
Above all accomplishments, character matters most. |
